Hi everyone!
I am trying to make sense of running inference using the scrfd models provided in the Hailo Model Zoo and have a few questions:
- To run meaningful inference using a scrfd model (e.g. scrfd_2.5g), I need to/should use the postprocessor script from the Hailo Model Zoo located under
hailo_model_zoo/core/postprocessing/face_detection, right? - To use the postprocessor, I need to supply the anchor sizes. I obtained those by looking at
hailo_model_zoo/cfg/base/scrfd.yamland copying the values from there into a simple dict like this:anchors = {"steps": [8, 16, 32], "min_sizes": [[16, 32], [64, 128], [256, 512]]}. Is this correct? (And if so, wouldn’t it make sense to declare these values as deefaults in the script?) - Finally, I would need to actually perform the postprocessing using the
tf_postprocfunction. Here is where I’m stuck - what exactly are the endnodes supposed to be? I copied the approach from the Hailo-Application-Example code - Python - Streaming example that is based on a yolox model. However, the desired inputs and ways to use the postprocessor differ. Based on the output shape of scrfd and the endnodes used in the code example, I assume that I have to derive the endnodes in some way from the output shape of the model - but the numbers used in the example code look essentially like magic numbers to me. Could someone help me out here?
As I plan on using Hailo-8 in a commercial environment and am unfortunately in no position to purchase some sort of license from DeGirum, using DeGirum’s PySDK is not an option here
