Inference for Multi-Modal Model
Dear community,
Is it possible to infer a multi-modal model with Hailo-8? I have a project that requires me to use object detection (so image data as input) and sound recognition (so sound data as input) so I want to use 1 multi-modal instead of 2 different models. Is it possible?
Thank you!
Hey @nino,
Yes, it is possible to use multi-modal models with the Hailo-8. For more information on how to do this and utilize the model effectively, I recommend referring to the following sections in our documentation:
HailoRT User Guide:
  • Input and Output VStream Setup
  • Virtual Devices and Multi-Network Support
Hailo Model Zoo User Guide:
  • Model Quantization and Compilation
  • Supported Architectures
Additionally, you can run these models in parallel using the scheduler.
Best Regards,
Omria
