How to run inference using ONNX file
I want to run inference using my custom trained yolov8. What i should do?
I have .pt file and onnx file.
Can I run inference by using onnxruntime:
or I must first convert onnx to hef file and then run inference by using i.e this code examples??
I try convert onnx to hef but i have some problems…
like:
raise FileNotFoundError(f"Couldn’t find dataset in {data_path}. Please refer to docs/DATA.rst.")
FileNotFoundError: Couldn’t find dataset in /home/usser/.hailomz/data/models_files/coco/2021-06-18/coco_calib2017.tfrecord. Please refer to docs/DATA.rst.
Yes, you first must convert the model into the HEF format.
The dataset mentioned here can be created using the instruction here:
GitHub - Hailo Model Zoo - DATA
However, you said
That means you need to use images from your own dataset. The Model Zoo will use the COCO dataset for this model. See
GitHub - Hailo Model Zoo - yolov8m.yaml
Check this page last section:
GitHub - Hailo Model Zoo - Training - Yolov8
If you have not done so yet, please also work trough the tutorials in the Hailo AI Software Suite about the model conversion workflow. Inside the docker simply type:
hailo tutorials
Thanks for your reply.
I read these documents, but I’m still confused.
To be clarify, my model is yolov8n, but I used 3 classes, and other input version (1024x1024), and this model was trained on my custom dataset.
So how can I convert it from onnx to hef ? I also need to do it with int16
After reading these docs, I get more questions:
  • start_node_names (list of str, optional): Name of the first ONNX node to parse.
  • end_node_names (list of str, optional): List of ONNX nodes, that the parsing can stop after all of them are parsed.
I understand that I can get these nodes names from my onnx file, but hm… in yolov8n I have:
Input [image, batch x channels x width x height] →
Node name: /model.0/conv/Conv
Input(s): images, model.0.conv.weight, model.0.conv.bias
Output(s): /model.0/conv/Conv_output_0
Op type: Conv
some convs, concat, split … etc
at the end:
Node name: /model.22/Div_1
Input(s): /model.22/Add_2_output_0, /model.22/Constant_11_output_0
Output(s): /model.22/Div_1_output_0
Op type: Div
Node name: /model.22/Sub_1
Input(s): /model.22/Add_1_output_0, /model.22/Sub_output_0
Output(s): /model.22/Sub_1_output_0
Op type: Sub
Node name: /model.22/Concat_4
Input(s): /model.22/Div_1_output_0, /model.22/Sub_1_output_0
Output(s): /model.22/Concat_4_output_0
Op type: Concat
Node name: /model.22/Constant_12
Input(s):
Output(s): /model.22/Constant_12_output_0
Op type: Constant
Node name: /model.22/Mul_2
Input(s): /model.22/Concat_4_output_0, /model.22/Constant_12_output_0
Output(s): /model.22/Mul_2_output_0
Op type: Mul
Node name: /model.22/Sigmoid
Input(s): /model.22/Split_output_1
Output(s): /model.22/Sigmoid_output_0
Op type: Sigmoid
Node name: /model.22/Concat_5
Input(s): /model.22/Mul_2_output_0, /model.22/Sigmoid_output_0
Output(s): output0
Op type: Concat
So.. i find some instructitons when is describes that i should use configurations file ".yaml:
what is it???
anchors:
scale_factors:
- 0.5
- 0.5
regression_length: 15
nms_postprocess(“../../postprocess_config/yolov8s_nms_config.json”, meta_arch=yolov8, engine=cpu)
Why is the normalization and output changing?
I saw on the graph after converting from onnx to har that my architecture is changing and I don’t know why.
Why do I have to use images from my dataset when using the zoo model?
Should I prepare the data in the same format as in the examples? Labels, images, folder tracking / val
And how to use config files?
…there is too much information out there, making me a little lost and I don’t know how to convert onnx to hef correctly
Here is also
but hm, when i change input shape i shoudl change eanchors values?? but how?
