How to improve the conversion quality?
Hello, I have an UNet network used for infrared image reconstruction. After training, I exported the ONNX model and tested it, achieving a PSNR of up to 39 dB.
My DFC conversion and test code is as follows. The converted PSNR is only 32 dB, as shown in the code. I also used the highest optimization level and the lowest compression rate. Is the converted result normal?
    runner = ClientRunner(hw_arch=HW_ARCH)
        onnx_path,
        onnx_model_name,
        net_input_shapes={"input": [8,1,480, 640]},
        start_node_names=["input"],
        end_node_names=["output"],
def prepare_calibration_data( num_images=1024):
    calib_data = []
    image_files = [f for f in os.listdir(CALIB_DIR) if f.endswith('.bmp')][:num_images]
    for img_name in image_files:
        img_path = os.path.join(CALIB_DIR, img_name)
        with Image.open(img_path) as img:
            img = img.resize((640, 480))
            img_array = np.array(img, dtype=np.uint8)
            calib_data.append(img_array)
    return np.array(calib_data).reshape(num_images,480, 640,1)
def optimize_model(runner, logger):
    calib_dataset = prepare_calibration_data(logger, num_images=1024)
    np.random.shuffle(calib_dataset)
    model_script = f"""
normalization1 = normalization([127.5], [127.5])
post_quantization_optimization(adaround, policy=enabled,shuffle=False,batch_size=16,learning_rate=0.001)
model_optimization_flavor(optimization_level=4,compression_level=0)
    with tempfile.NamedTemporaryFile(mode='w', suffix='.alls', delete=False) as f:
        f.write(model_script)
        script_path = f.name
        runner.load_model_script(script_path)
    runner.save_har(QUANT_HAR_PATH)
def compile_to_hef():
    runner = ClientRunner(har=QUANT_HAR_PATH)
    hef = runner.compile()
    with open(HEF_PATH, "wb") as f:
        f.write(hef)
def validate_quantized_model(logger):
    test_image = prepare_test_data(num_images=1)[0:1]  # 单张测试图像
    with runner.infer_context(InferenceContext.SDK_QUANTIZED) as ctx:
        quant_output = runner.infer(ctx, test_image)
    output_array = (quant_output[0] * 0.5 + 0.5) * 255  # 反归一化
    output_array = np.clip(output_array, 0, 255).astype(np.uint8).squeeze()
    output_img = Image.fromarray(output_array)
    output_img.save("test_out.bmp")
Some print information during the conversion process is as follows.n
It is worth noting that the results obtained by my use of full 16-bit quantization are quite similar to those obtained by full int8 quantization.
So, how can I improve the converted PSNR?
[info] Model Optimization Algorithm Layer Noise Analysis is done (completion time is 00:00:59.45)
[info] Output layers signal-to-noise ratio (SNR): measures the quantization noise (higher is better)
[info]  unet_pruned/output_layer1 SNR:  33.36 dB
Good job, that’s a high SNR :slight_smile:
For a next step, I would recommend using accuracy metrics to see if further improvement is really needed. You can use the emulator if you want to avoid going through the compilation step.
