Creating a new thread for this since the majority of the posts I’ve seen on this (such as ths one) are typically referring to the raspberry pi
I didn’t expect so many issues with the setup since I’m using the docker container.
when I run hailortcli scan I’ll get the following:
(hailo_virtualenv) hailo@citi-ai:/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_tutorials/notebooks$ hailortcli scan
[HailoRT] [error] Can't find hailort driver class. Can happen if the driver is not installed, if the kernel was updated or on some driver failure (then read driver dmesg log)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64) - Failed listing hailo devices
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64)
uname -a output if this is required:
(hailo_virtualenv) hailo@citi-ai:/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_tutorials/notebooks$ uname -a
Linux <redacted-name> 5.15.0-134-generic #145~20.04.1-Ubuntu SMP Mon Feb 17 13:27:16 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
any help would be really appreciated! I set out over 2weeks back now with Hailo, and haven’t even got a running .hef model yet, let alone anything else
