Welcome to the Hailo Community @anon17881598!
There seems to be a significant accuracy decrease. This means there’s noise resulting from the quantization.
It is unlikely that this would have an effect.
Here are a few things you can try:
- Make sure you are using as a base the ModelZoo model script for the quantization
- Add this solution to your model script.
- Add more images to your calibset
- Try using Adaround as a post-quant alg
- Set the output to 16-bit - please note that this negatively affects the FPS
