I made the mistake to update my raspberry - after this none of my Hailo Clip code is working anymore. I am getting the following error after executing source setup_env.sh
I wrote a bunch of custom code around the hailo examples so I would like to avoid to reinstall everything.
Any guideline how to resolve the Driver version mismatch would be greatly appreciated.
StephanS@raspberrycatcam:~ $ ./catcam_CLIP_start.sh
Setting up the environment...
Setting up the environment for hailo-tappas-core...
TAPPAS_VERSION is 3.31.0. Proceeding...
You are not in the hailo_clip_venv virtual environment.
Virtual environment exists. Activating...
TAPPAS_POST_PROC_DIR set to /usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes
[HailoRT] [error] CHECK failed - Driver version (4.19.0) is different from library version (4.20.0)
Error: Device Architecture not found. Please check the connection to the device.
