Hailo AI SW Suite Dockerfile
Is it possible to provide the Dockerfile for the Hailo AI SW Suite container?
I will be using both Nvidia Deepstream 7 and Halio for my application, so I need to create a container which has both.
Hello @jasonlanclos,
I will check if we can provide the Dockerfile you requested and get back to you with an answer. In the meantime, if you would like to use our existing Docker image and build on top of it, please check out the following guide:
This guide will walk you through the steps to install and use the Hailo Docker image. Let me know if you have any other questions!
Best regards,
Hello @omria ,
For my current project I would need to install Hailo DFC and HailoRT in my own docker image (doing it the other way is not possible).
Any news on providing the Dockerfile for the Hailo SW Suite?
Best regards,
Hello @omria ,
Is there anything new on this ? I also would need a working dockerfile if possible.
Best regards
