Jusat have been wondering if there is a docker file for Ubuntu 20.04 which has tappas and hailo AI Suite is implemented. I have found quite a few Docker files but have yet to find a Dockerfile that has Ubuntu 20.04
Hey @samjang9509,
Just to update you regarding Docker support:
The current AI Suite Docker (October 2024 release) supports:
- Ubuntu 20.04
- Ubuntu 22.04
Important Note: Ubuntu 20.04 support may be deprecated soon:
- We’re planning to add Ubuntu 24.04 support
- Ubuntu 20.04 support will likely be removed in future releases
We recommend planning to migrate to a newer Ubuntu version for long-term compatibility.
Let me know if you need any help with the migration process!
Hey @omria
I don’t seem to be able to find the Ubunto 20.04 AI Suite Docker is it possible it has already been removed?
Regards,
Hi @samjang9509,
The file is the same for both (it’s a Docker file). You can find the installation instructions here: Hailo SW Suite Installation.
Hi @omria,
The Docker file that I can find from the Developer zone which I have installed
is was an image with Ubuntu 22.04 as it’s OS, I believe there isn’t a way to change to just change that to 20.04 unless I have a .tar/.tar.gz file that has an image with Ubuntu 20.04 in it. But I don’t seem to see it in the Developer zone.
Regards,
Hi @omria,
I seem to have found it in the Archive I just found the button to change the downloadable files that I can download from latest release to archive.
Regards,
