Hailo-8 farm :-)
We are developing a carrier board with a NVIDIA jetson orin nano and 12 M2 pcie slots.
It’s normal use is to control 12 JNX400 boards with up to 48 NVIDIA jetsons in a 19" rack. :slight_smile:
We want to test 12 hailo-8 M.2 modules on this board.
4 key M slots are connected with 2 pcie lanes.
8 key M slots are connected with 1 pcie lane.
Is it possible to drive a hailo-8 M.2 module with only 1 lane ?
Where can i find pcie drivers running on jetson orin nano ( arm 64 , linux for tegra, near ubuntu 18.04 ).
Regards andi
Hey @auvidea.as,
Yes, you can run the Hailo 8 using only a single lane. The performance will be on par with Raspberry Pi connections, as they also use a single lane.
You can find all of our software versions at https://hailo.ai/developer-zone/software-downloads/. For older versions, please check the archive section on that page.
Feel free to reach out if you have any other questions!
Best Regards,
Omria
Thank you,
the hailo-pcie driver is running on this board:
The compute modul is a jetson xavier nx with ubuntu 18.04 and today i will try to run hailort on docker with ubuntu 22.04.
Hope it works.
Best regards, andi
Hi, hailortcli ist running but lspci -v tells:
0005:06:00.0 Co-processor: Device 1e60:2864 (rev 01)
  • Subsystem: Device 1e60:2864*
  • Flags: bus master, fast devsel, latency 0, IRQ 35*
  • Memory at 1c00000000 (64-bit, prefetchable) [size=16K]*
  • Memory at 1c00008000 (64-bit, prefetchable) [size=4K]*
  • Memory at 1c00004000 (64-bit, prefetchable) [size=16K]*
  • Capabilities: [80] Express Endpoint, MSI 00*
  • Capabilities: [e0] MSI: Enable- Count=1/1 Maskable- 64bit+*
  • Capabilities: [f8] Power Management version 3*
  • Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>*
  • Capabilities: [108] Latency Tolerance Reporting*
  • Capabilities: [110] L1 PM Substates*
  • Capabilities: [128] Alternative Routing-ID Interpretation (ARI)*
  • Capabilities: [200] Advanced Error Reporting*
  • Capabilities: [300] #19*
  • Kernel driver in use: hailo*
  • Kernel modules: hailo_pci*
and:
dmesg | grep hailo
[ 5.829245] hailo_pci: loading out-of-tree module taints kernel.
[ 5.831571] hailo: Init module. driver version 4.19.0
[ 5.831970] hailo 0005:06:00.0: Probing on: 1e60:2864…
[ 5.832083] hailo 0005:06:00.0: Probing: Allocate memory for device extension, 11632
[ 5.832399] hailo 0005:06:00.0: enabling device (0000 → 0002)
[ 5.832429] hailo 0005:06:00.0: Probing: Device enabled
[ 5.832683] hailo 0005:06:00.0: Probing: mapped bar 0 - 000000001eccc50d 16384
[ 5.832826] hailo 0005:06:00.0: Probing: mapped bar 2 - 0000000002333a39 4096
[ 5.832964] hailo 0005:06:00.0: Probing: mapped bar 4 - 000000003d955230 16384
[ 5.833124] hailo 0005:06:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 5.833277] hailo 0005:06:00.0: Probing: Enabled 64 bit dma
[ 5.833387] hailo 0005:06:00.0: Probing: Using specialized dma_ops=iommu_dma_ops
[ 5.834119] hailo 0005:06:00.0: Probing: Using userspace allocated vdma buffers
[ 5.834313] hailo 0005:06:00.0: Disabling ASPM L0s
[ 5.834630] hailo 0005:06:00.0: Successfully disabled ASPM L0s
[ 5.834959] hailo 0005:06:00.0: Writing file hailo/hailo8_fw.bin
[ 6.122420] hailo 0005:06:00.0: File hailo/hailo8_fw.bin written successfully
[ 6.122593] hailo 0005:06:00.0: Writing file hailo/hailo8_board_cfg.bin
[ 6.122763] Failed to write file hailo/hailo8_board_cfg.bin
[ 6.122869] hailo 0005:06:00.0: File hailo/hailo8_board_cfg.bin written successfully
[ 6.123003] hailo 0005:06:00.0: Writing file hailo/hailo8_fw_cfg.bin
[ 6.123143] Failed to write file hailo/hailo8_fw_cfg.bin
[ 6.123241] hailo 0005:06:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[ 6.222090] hailo 0005:06:00.0: Firmware loaded successfully
[ 6.242764] hailo 0005:06:00.0: Probing: Added board 1e60-2864, /dev/hailo0
The Driver is not running. :frowning:
@auvidea.as The log file you sent seems ok.
The files hailo8_fw_cfg.bin and hailo8_board_cfg.bin are optional. The hailo8_fw.bin is mandatory and is has been written correctly.
How did you determine that the driver is not running?
Please try the following:
  • Scan for the device (same as lspci):
    hailortcli scan
  • Check if you can read the firmware configuration:
  • Check if you can run inference:
    hailortcli run <HEF-PATH>
    You can download a precompiled HEF from the Hailo Model Zoo for this purpose.
If you do not have issues with these commands, it means you can successfully communicate with the device.
Hi, thanks for your post.
The hailo-pcie-driver is installed on l4t 18.04.
The hailort ist installed in docker image ( Ubuntu 22.04.5 LTS )
In the Dockerimage the device file /dev/hailo0 doesn’t exist.
I think that is the problem.
So your commands doesn’t work:
root@015c21ec22c1:/app# hailortcli scan
Hailo Devices:
[-] Device: 0005:06:00.0
root@015c21ec22c1:/app# hailortcli fw-control identify
[HailoRT] [error] CHECK failed - Failed to open device file /dev/hailo0 with error 2
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_FAIL(36)
Regards as
@auvidea.as could you please specify which commands you used to run the docker?
See below the commands used by the Hailo AI SW Suite docker, which uses the HailoRT PCIe driver installed on the main system:
  DOCKER_ARGS="--privileged \
               --net=host \
               -e DISPLAY=$DISPLAY \
               -e XDG_RUNTIME_DIR=$XDG_RUNTIME_DIR \
               --device=/dev/dri:/dev/dri \
               --ipc=host \
               --group-add 44 \
               -v /dev:/dev \
               -v /lib/firmware:/lib/firmware \
               -v /lib/modules:/lib/modules \
               -v /lib/udev/rules.d:/lib/udev/rules.d \
               -v /usr/src:/usr/src \
               -v ${XAUTH_FILE}:/home/hailo/.Xauthority \
               -v /tmp/.X11-unix/:/tmp/.X11-unix/ \
               --name $CONTAINER_NAME \
               -v /var/run/docker.sock:/var/run/docker.sock \
               -v /etc/machine-id:/etc/machine-id:ro \
               -v /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket \
               -v $(pwd)/${SHARED_DIR}/:/local/${SHARED_DIR}:rw \
               -v /etc/timezone:/etc/timezone:ro \
               -v /etc/localtime:/etc/localtime:ro
If not done yet, I suggest trying the following commands when running the docker:
  • --privileged, to grant the container full access to the host’s devices and kernel features.
  • --device=/dev/dri:/dev/dri and -v /dev:/dev, to share specific device nodes (/dev/dri) and all devices (/dev) with the container.
  • -v /lib/firmware:/lib/firmware and -v /lib/modules:/lib/modules, to mount the host’s firmware and kernel module directories into the container.
  • -v /lib/udev/rules.d:/lib/udev/rules.d, to make sure the devices are recognized properly within the container.
Let me know if this works for you.
