Guide to using the DFC to convert a modified YoloV11 on Google Colab
Hello, you can find all of the software downloads here after you’ve signed in:
https://hailo.ai/developer-zone/software-downloads/
@ kasun.thushara.1800
Thanks for your notebooks! It is really helpful will also work for yolov8s model?
Also how did you know what to put in the nms layer json? or which layers to put in the quantization script?
it will work for that. You need to verify the endpoints. You can use netron app to check the endpoints. and for nms json use this
can i use opset version as 14?
@trieut415 When trying to run inference I got:
Condition 'input_tensor->shape()[ 1 ] == 4 + m_OutputNumClasses' is not met: input_tensor->shape()[ 1 ] is 1, 4 + m_OutputNumClasses is 6
I strugling on it..waste already a lot of time.
Hi @user131
From the error message, it looks like it is from DeGirum PySDK. Please see User Guide 3: Simplifying Object Detection on a Hailo Device Using DeGirum PySDK
Hi! I have been successfully compiled few times for hailo8l.
Now while trying to do the same for hailo8 I see strange compiling logs which not changes for a while.
Yolo model is same, all parameters is same except chosen_hw_arch = “hailo8”
Previously I used hailo8l
I found out one interesting think.
This is logs from starting compiling for hailo8l
[info] ClientRunner initialized successfully.
[info] Adding an output layer after conv46
[info] Adding an output layer after conv47
[info] Adding an output layer after conv56
[info] Adding an output layer after conv57
[info] Building optimization options for network layers...
[info] Successfully built optimization options - 3s 375ms
[info] Successfully built optimization options - 6s 579ms
[info] Resources optimization params: max_control_utilization=100%, max_compute_utilization=100%, max_compute_16bit_utilization=100%, max_memory_utilization (weights)=85%, max_input_aligner_utilization=100%, max_apu_utilization=100%
[info] Finding the best partition to contexts...
[.........<==>...........................] Duration: 00:02:16
Found valid partition to 3 contexts
[info] Searching for a better partition...
[................................<==>....] Duration: 00:01:58
Found valid partition to 3 contexts, Performance improved by 20.7%
[.......<==>.............................] Duration: 00:01:00
Found valid partition to 3 contexts, Performance improved by 1.8%
[.<==>...................................] Duration: 00:00:38
Found valid partition to 3 contexts, Performance improved by 9.9%
[...............................<==>.....] Duration: 00:00:19
Found valid partition to 3 contexts, Performance improved by 2.7%
This is logs for compiling for hailo8
[info] Successfully built optimization options - 3s 338ms
[info] Running Auto-Merger
[info] Auto-Merger is done
[info] Resources optimization params: max_control_utilization=120%, max_compute_utilization=100%, max_compute_16bit_utilization=100%, max_memory_utilization (weights)=90%, max_input_aligner_utilization=100%, max_apu_utilization=100%
[info] Validating layers feasibility
Validating best_context_0 layer by layer (100%)
● Finished
[info] Layers feasibility validated successfully
[info] Running resources allocation (mapping) flow, time per context: 9m 59s
Context:0/0 Iteration 0: Mapping prepost...
          cluster_0  cluster_1  cluster_2  cluster_3  cluster_4  cluster_5  cluster_6  cluster_7  prepost
 worker0  *          *          *          *          *          *          *          *          V
Main difference in Single-cintext and Multi-context.
What I found out that single context never working in my current compilation.
I made some changes in code optimize_model.py script by adding block
alls = """
context_switch_param(mode=enabled)
This ensure that hailo8 compilation would use multi-context. It compiled despite lot of Trying parallel splits red sectors.
With such logs:
[info] Successfully built optimization options - 6s 597ms
[info] Successfully built optimization options - 6s 508ms
[info] Running Auto-Merger...............] Elapsed: 00:01:30
[info] Auto-Merger is done...............] Elapsed: 00:01:37
[...........................<==>.........] Duration: 00:27:07
[.<==>...................................] Duration: 00:01:46
Found valid partition to 3 contexts, Performance improved by 2.1%
[...........................<==>.........] Elapsed: 00:16:25
[info] Partition to contexts finished successfully
[info] Partitioner finished after 170 iterations, Time it took: 45m 21s 153ms
[info] Applying selected partition to 3 contexts...
● Finished
Validating best_context_1 layer by layer (100%)
● Finished
Validating best_context_2 layer by layer (1%)
Validating best_context_2 layer by layer (3%)
Validating best_context_2 layer by layer (4%) +  +  +  +  +
Validating best_context_2 layer by layer (6%) +  +  +  +  +
Validating best_context_2 layer by layer (7%) +  +  +  +  +
Validating best_context_2 layer by layer (9%) +  +  +  +  +
Validating best_context_2 layer by layer (10%)+  +  +  +  +
But…
While running two same scripts by trying detecting object on camera stream showing same picture on monitor, detection function time that it spend to run model inference almost same, hailo8l model inference even fast for 0.01 s. Like 0.38-39 to 0.37-0.38.
Just in case @shashi I am using degerium sdk for that.
So, hailo8 compilation in single-context never good (always timeout as on screenshots in previous post reply), but with multi-context it not faster than inference on hailo8l model.
Community or support, pls help!
Fixed^^
I removed from optimization step script
So it uses default, it takes little bit more time for optimization, but compiler used Single-context was super fast. Almost rapidly model compiled.
I got 0.21-0.22 inference time. So, hailo8 2time faster than hailo8l with Multi-context.
I think I need a try to explicitly set Single-context for hailo8l arch compilation.
I have try to install DFC in my_env as follows :
!my_env/bin/pip install /content/drive/MyDrive/hailo_dataflow_compiler-3.33.0-py3-none-linux_x86_64.whl
However, when i run :
!my_env/bin/hailo --version
The result gives error as follow :
  File "/content/my_env/bin/hailo", line 3, in <module>
    from hailo_sdk_client.tools.cmd_utils.main import main
  File "/content/my_env/lib/python3.10/site-packages/hailo_sdk_client/__init__.py", line 29, in <module>
    import hailo_model_optimization  # noqa: F401
  File "/content/my_env/lib/python3.10/site-packages/hailo_model_optimization/__init__.py", line 57, in <module>
    _ = tf.nn.conv2d(dummy_input, dummy_kernel, strides=1, padding="SAME")
  File "/content/my_env/lib/python3.10/site-packages/tensorflow/python/util/traceback_utils.py", line 153, in error_handler
  File "/content/my_env/lib/python3.10/site-packages/tensorflow/python/framework/ops.py", line 6002, in raise_from_not_ok_status
    raise core._status_to_exception(e) from None  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: {{function_node __wrapped__Conv2D_device_/job:localhost/replica:0/task:0/device:GPU:0}} No DNN in stream executor. [Op:Conv2D] name:
I have installed python 3.10 in my_env, since i want to convert YOLOv11 for Hailo-8l device.
This is my Google Colab link
Please kindly help to solve this problem. Thank you :slight_smile:
Hello!
Are you on a GPU runtime? This won’t work on the default CPU.
Hello @trieut415
I am using T4 GPU runtime during the session in Google Colab.
I select it from Runtime > Change Runtime type, then I selected T4 GPU, over CPU and v5e-1 TPU.
Is it the correct GPU to be selected?
