Error when creating multiple instances of HailoAsyncInference
When I tried to create multiple instances of HailoAsyncInference, and load a model in each instance and run it in a separate thread, the first instance was created without any issue, but it reports error for the second instance like this:
[HailoRT] [error] CHECK failed - Failed to create vdevice. there are not enough free devices. requested: 1, found: 0.
Does it mean one Hailo device can only load and run one model at any time (my model size is about 2 MB), or there is some other way to run multiple models on one Hailo device?
Thanks!
Hey @TT2024,
If you’re looking to run multiple models, we recommend using the scheduler rather than creating multiple vdevice instances (HailoAsyncInference). The scheduler is specifically designed for managing multiple model executions efficiently.
Thanks for your suggestion! Do you have some simple examples that I can start with?
Never mind, I will check out this one first:
Hi @omria , I would like to do switching/loading models manually. How can I check if the hailo device is busy (running another model) before I load a new model?
Thanks for your help!
Hey @TT2024 ,
This is the basic flow :
  1. Create one HailoDevice.
  2. Load and run the first model.
  3. When needed, unload the model (call .release()).
  4. Load the new model and continue inference.
Hi @omria , thank you very much! (BTW, I believe by “HailoDevice”, you meant VDevice of hailo_platform library.)
