Thank you @u2185645 for sharing a test block of your model.
A few notes on that-
- The Hailo operates on 4-dim tensors, where the batch dim is always 1, and being set dynamically. In your test block the dims changes to 3 in the middle:
- With the above, ops like Gather, reshape can typically pose challenges to convert the network, these can sometime be addressed by usign ONNX-simplifier, that comes pre-installed with the DFC, but not always.
- Transpose operation can also pose challenge, especially when it involves the batch (0th) dimension.
- Last point is related to the original ONNX that you’ve tried to convert. 8GB ONNX, means roughly a 2G parameter model. This currently not supported usecase, see this Dataflow Compiler (DFC) Availability! link
