Hello @shashi, this is exactly what I’ve been looking for. I have lost days in the process of compiling a .hef for yolo models. I believe that I have requested access, excited to try this tool out!
Welcome to the Hailo community.
We received your request and are currently processing it. Once approved, we will email you with instructions.
You should now have access to our cloud compiler. Please try and let us know if you encounter any issues.
Hi @shashi i got a question I haven’t tested on this cloud compiler yet, since i dont have acces to it, is it the similar compiler that Hailo provided, or did you guys made some changes . Out of curiosity, your compiler and Hailo should work the same, right? The only difference is you guys rectify the error and make it into web based version, right?
Hi @SAN
The compiler itself is from Hailo. Most of the users have difficulty in setting up things correctly. So, we just wrapped the compiler into an easy-to-use tool where the setup is well tested. We do not claim to have rectified any errors as the compiler code we use is the same as what everyone else has access to. In other words, we do not have any extra magic inside
. It is just a reliable setup that has been extensively tested.
In case you did not know: you can request access to the compiler by filling out the form above.
“Thank you for the clarification @shashi . I’ll look through it.”
Hi @shashi
Could you please let me know what compression level is used in the cloud compiler?
Hi @user99
Compression level is Zero.
Good Day,
I’ve already sent a request for accessing the Cloud Compiler, huge thanks for developing it. It would be helpful for my Object Detection project that I am developing.
Hi @junemel
Welcome to the Hailo community. We received your request and will be processing it. Once approved, we will reach out to you via email and provide instructions.
I just found out about this. It was taking a few hours on my machine to convert onnx to hef, so I can’t wait to try this out! I’ve already sent the request for accessing the compiler.
Hi @Fong_Zi_Hao
We received your request. Once approved, we will reach out to you via email with further instructions.
Hi @shashi, thank you for your work!
I’ve already submitted a request for accessing the Cloud Compiler, many thanks for creating this tool. It would be very beneficial for my Pose Estimation project that I’m currently working on!
Thank you for your kind words. We received your request and are processing it. Once approved, you will receive an email with instructions.
Is the compression level default for all models supported by Hailo?
Compression level is zero.
Thank you that I found this thread, after struggling on converting onnx to hef. This tool will give hope on my on-going project.
I waited 6 hours of optimization only to check that my hef is not working.
This would be a big help. thank you in advance
Cant believe i didnt come across this earlier, applied for access and really excited to try this out!!
Is it compiled with a specific version of the dfc , or can you choose which one to compile with?
It uses a specific version of the DFC. We are processing your request and will keep you posted.
Hello Sir,
I also applied for access, Hoping for your approval. thanks
