Hi community,
I am facing this error message when running ./detection.sh. Before I run the TAPPAS container, I already installed the Hailort PCIe driver and verified with the hailort fw control-identify command. Please advice.
Hi community,
Hey @zihao.wong,
To run TAPPAS, you need to be within the virtual environment of TAPPAS. Could you let me know which version of TAPPAS you’re using? It looks like the driver works fine outside of the TAPPAS environment, so this issue might be caused by a mismatch between the driver and HailoRT version, especially if you’re using an older version of TAPPAS.
Hi Omria,
We are using TAPPAS V3.28.0 and the hailort-pcie-driver 4.18.0.
Indeed, that appears to be the source of the problem. To resolve this issue, please ensure you’re using the most recent version of Tappas, specifically either version 3.29 or 3.29.1.
Issue resolved, thanks Omria!
