Can't compile from onnx to hef on Mac m1
Can’t use DFC to compile my onnx to hef as I am not on a x86 cpu (creating a virtual environment won’t help as avx still won’t be supported) and the raspberry is of course aarch64 so won’t work to compile it there either. I am stuck, have i wasted my money? Please please please link a guide that can get me over this roadblock (the ones in hailo.ai do not cover this). My goal was to convert it from onnx to hef with DFC then clone hailo model zoo, and run the model from there. Is there nothing that can be done?
I’m using Macos M1 Max 2021
The Hailo Dataflow Compiler has several dependencies and special requirements like AVX. Therefore, we officially support it only on x86-based Ubuntu (version 20 and 22) and WSL2.
Since it’s 2025, x86 machines are still widely available. You can likely find access to one nearby. Alternatively, you may also consider using cloud-based solutions that provide x86-based environments.
Followed your advice and i got dataflow compiler installed, when i run hailo -h i get:
(hailo_env) tfolbaek@fridge-instance-ubuntu:~/hailo_model_zoo$ hailo -h
[info] Current Time: 02:20:30, 02/19/25
[info] CPU: Architecture: x86_64, Model: INTEL(R) XEON(R) PLATINUM 8581C CPU @ 2.30GHz, Number Of Cores: 8, Utilization: 0.0%
[info] Memory: Total: 29GB, Available: 28GB
[info] System info: OS: Linux, Kernel: 6.8.0-1021-gcp
[info] Running hailo -h
usage: hailo [-h] [–version] {analyze-noise,compiler,params-csv,parser,profiler,optimize,tb,visualizer,tutorial,har,join,har-onnx-rt,runtime-profiler,dfc-studio,help} …
Hailo Command Line Utility
positional arguments:
Hailo utilities aimed to help with everything you need
analyze-noise Analyze network quantization noise
compiler Compile Hailo model to HEF binary files
params-csv Convert translated params to csv
parser Translate network to Hailo network
profiler Hailo models Profiler
optimize Optimize model
tb Create Tensorboard summary for Tensorflow model
visualizer HAR visualization tool
tutorial Runs the tutorials in jupyter notebook
har Query and extract information from Hailo Archive file
join Join two Hailo models to a single model
har-onnx-rt Generates ONNX-Runtime model including pre/post processing
runtime-profiler Hailo Runtime Profiler
dfc-studio Start DFC Studio
help Show the list of commands
options:
-h, --help show this help message and exit
–version show program’s version number and exit
However the output of my conversion:
(hailo_env) tfolbaek@fridge-instance-ubuntu:~$ hailomz compile yolov8s --ckpt=best.onnx --hw-arch hailo8l --calib-path /images --classes 8 --performance
File “/home/tfolbaek/hailo_env/bin/hailomz”, line 33, in
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/main.py”, line 101, in run
from hailo_model_zoo.main_driver import compile, evaluate, optimize, parse, profile
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 16, in
from hailo_model_zoo.core.main_utils import (
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 18, in
from hailo_model_zoo.core.infer import infer_factory
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/core/infer/infer_factory.py”, line 14, in
discovered_plugins = {name: importlib.import_module(name) for _, name, _ in iter_namespace(hailo_model_zoo.core.infer)}
File “/usr/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “/home/tfolbaek/hailo_model_zoo/hailo_model_zoo/core/infer/hw_infer_utils.py”, line 6, in
from hailo_platform import (
ModuleNotFoundError: No module named ‘hailo_platform’
Have you been able to solve this problem?
Nope, giving up and spending time learning other topics until they fix or refine their software :slight_smile:
I’ve succeeded in compiling on M4 with docker (same architecture as M1)
There are some tradeoffs ofc, but in the end inference is absolutely fine.
How ?
Can you explain it how how run it ? Do you used v5.3.0 ?
Fair point, I’ve successfully compiled for Hailo-8, and I’m still fighting with 5.3.0.
Now everything stops on hailo compiler stage, where I get bold [error] StopIteration: without any explanation. When I’ve traced the problem, I found out that it breaks on nms_postprocess_node stage. This is truly weird since I’ve explicitly said no to this:
Would you like to add nms postprocess command to the model script? (y/n)
n
So, my next step is to figure out if it’s a model or hailo issue.
But after some research, I don’t see the reason anymore why I should bother about 10h accelerator and 5.3.0 stack for CV only (which I do), so I’m planning to get back Hailo-8 and live peaceful life.
If you’re doing CV only, this is my best recommendation to you as well.
Ooooook, hailo10h is running live inference. It was never the model.
Repro: Suite 5.3.0, --hw-arch hailo10h, raw --end-node-names, no on-chip NMS. Clean on hailo8 from scratch.
If the compiler segfaults under qemu, switch Docker to Apple Virtualization + Rosetta. QEMU can’t run the 5.3.0.
The 5.3.0 parser auto-detects YOLO heads and quietly bakes an NMS postprocess into the .har: nms.json, postprocess.onnx, the nms_* metadata. The (y/n) prompt is trash and not doing the job: answering n suppresses the model-script line and nothing else, the artifacts are already written. So at compile, save_integrated_pb goes hunting for an NMS node that was never in the graph, next() comes up empty, and instead of an error you get a bare StopIteration.
So 5.3.0 is doable. Strip it out of the .har, re-pack, and optimise/compile.
Dear Hailo team, if you are there, two things that would’ve saved me a goddamn day:
  1. A (y/n) prompt where n actually declines, rather than decorating a decision you’ve already committed to disk.
  2. An exception with a message. A bare StopIteration out of a next() buried in pb_wrapper.py isn’t a diagnostic but a stack trace you’ve outsourced to your users. Same energy as the yolox auto-detect confidently mapping a model into The layer named "" doesn't exist in the HN.
