Steps to reproduce:
import tensorflow as tf
from math import factorial
def sin_series(x, order=6):
# Hailo doesn't support sin and cos and...
# Hailo supports only square and fractional powers in (0, 1) so we'll build hiegher powers sequentially
assert order > 1
result = x_prev = x
x_sq = x * x
for k in range(1, order):
x_prev = x_prev * x_sq
result = result + ((-1)**k / factorial(2*k+1)) * x_prev
return result
pos = tf.keras.Input(shape=(2048, 1, 2), name="kps0")
ft_proj = tf.keras.layers.Conv2D(32, 1, use_bias=False)
freqs = sin_series(ft_proj(pos))
model = tf.keras.Model(
{'pos': pos }, {'freqs': freqs},
name="ff_test"
model_name = "ff_test"
converter = tf.lite.TFLiteConverter.from_keras_model(model)
converter.target_spec.supported_ops = [
tf.lite.OpsSet.TFLITE_BUILTINS, # enable TensorFlow Lite ops.
tf.lite.OpsSet.SELECT_TF_OPS, # enable TensorFlow ops.
tflite_model = converter.convert() # may cause warnings in jupyter notebook, don't worry.
tflite_model_path = "models/ff_test.tflite"
with tf.io.gfile.GFile(tflite_model_path, "wb") as f:
f.write(tflite_model)
# Parsing the model to Hailo format
runner = ClientRunner(hw_arch='hailo8l')
hn, npz = runner.translate_tf_model(tflite_model_path, model_name)
You should see an error with the following stack trace in the end:
FuserHelper.run_broadcast_ew(self, layers)
172 pred0_shape = preds[0].output_shapes[index]
174 index = preds[1].outputs.index(layer.name)
--> 175 pred1_shape = preds[1].output_shapes[index]
177 does_apply_broadcast = FuserHelper.is_feature_broadcast(
178 pred0_shape,
179 pred1_shape,
180 is_two_sided=True,
181 ) or is_spatial_broadcast(pred0_shape, pred1_shape, is_two_sided=True)
183 if does_apply_broadcast:
IndexError: list index out of range
From my brisk stroll through the DFC codebase, I deduced that the problem is likely because for square operation multiple outputs are not created (and as a result multiple output shapes). Also, the fact that changing x_sq = x * x to x_sq = x * (x*0.9999999) makes it work points to the problem somewhere in the code of the operation.
