I’m trying to use a model called HybridNet on the Hailo-8. I converted it to ONNX, then generated a HAR file, and finally attempted to compile it into a HEF file. However, I encountered the following error. What could be the issue?
(hailo) jimin@jimin-Blade-15-RZ09-0485:~/hybridnets_mobinn$ hailo compiler --hw-arch hailo8 hybridnets_384x640_sim_optimized.har
[info] Current Time: 15:02:16, 02/20/25
[info] CPU: Architecture: x86_64, Model: 13th Gen Intel(R) Core™ i7-13800H, Number Of Cores: 20, Utilization: 2.3%
[info] Memory: Total: 30GB, Available: 24GB
[info] System info: OS: Linux, Kernel: 5.15.0-131-generic
[info] Running hailo compiler --hw-arch hailo8 hybridnets_384x640_sim_optimized.har
[info] Compiling network
[error] Mapping Failed (allocation time: 0s)
Not enough resize units. Streaming: 16 Non-Streaming: 0 in chip: 14
[error] BackendAllocatorException: Compilation failed: Not enough resize units. Streaming: 16 Non-Streaming: 0 in chip: 14
