I followed the dataflow compiler tutorial and jupyter notebooks on my main rig, those examples worked. I used them to take this model: https://github.com/ultralytics/yolov5/releases/download/v7.0/yolov5m.onnx to a hef file for the hailo 8l.
I am able to run on the rpi5:
matteius@matteius-desktop:~/Projects/tappas/apps/h8/gstreamer/raspberrypi/detection$ hailortcli run ~/yolov5m.hef
Running streaming inference (/home/matteius/yolov5m.hef):
Transform data: true
Type: auto
Quantized: true
Network yolov5m/yolov5m: 100% | 81 | FPS: 16.20 | ETA: 00:00:00
> Inference result:
Network group: yolov5m
Frames count: 81
FPS: 16.20
Send Rate: 159.22 Mbit/s
Recv Rate: 278.63 Mbit/s
But my question is how do I actually utilize the model? I tired modifying the detection.sh example:
diff --git a/apps/h8/gstreamer/raspberrypi/detection/detection.sh b/apps/h8/gstreamer/raspberrypi/detection/detection.sh
index 1358cf9..1a3e452 100755
--- a/apps/h8/gstreamer/raspberrypi/detection/detection.sh
+++ b/apps/h8/gstreamer/raspberrypi/detection/detection.sh
@@ -74,7 +74,11 @@ function parse_args() {
hef_path="$RESOURCES_DIR/ssd_mobilenet_v1.hef"
postprocess_so="$POSTPROCESS_DIR/libmobilenet_ssd_post.so"
thresholds_str=""
- elif [ $2 != "yolov5" ]; then
+ elif [ $2 == "yolov5" ]; then
+ network_name="hailo_yolo_inference"
+ hef_path="/usr/share/hailo-models/yolov5m.hef"
+ postprocess_so="/usr/local/lib/aarch64-linux-gnu/rpicam-apps-postproc/libyolo_hailortpp_post.so"
+ else
echo "Received invalid network: $2. See expected arguments below:"
print_usage
exit 1
matteius@matteius-desktop:~/Projects/tappas/apps/h8/gstreamer/raspberrypi/detection$ ./detection.sh --network yolov5
Running hailo_yolo_inference
gst-launch-1.0 filesrc location=/home/matteius/Projects/tappas/apps/h8/gstreamer/raspberrypi/detection/resources/detection.mp4 name=src_0 ! qtdemux ! h264parse ! avdec_h264 max_threads=2 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoscale n-threads=2 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailonet hef-path=/usr/share/hailo-models/yolov5m.hef batch-size=1 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailofilter function-name=hailo_yolo_inference so-path=/usr/local/lib/aarch64-linux-gnu/rpicam-apps-postproc/libyolo_hailortpp_post.so qos=false ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailooverlay ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! fpsdisplaysink video-sink=ximagesink name=hailo_display sync=false text-overlay=false
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
NMS score threshold is set, but there is no NMS output in this model.
CHECK_SUCCESS failed with status=6
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 46 ()
Value in failed request: 0xd
Serial number of failed request: 61
Current serial number in output stream: 65
Then when I take that gstreamer command and remove the nms output args I get:
gst-launch-1.0 filesrc location=/home/matteius/Projects/tappas/apps/h8/gstreamer/raspberrypi/detection/resources/detection.mp4 name=src_0 ! qtdemux ! h264parse ! avdec_h264 max_threads=2 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoscale n-threads=2 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailonet hef-path=/usr/share/hailo-models/yolov5m.hef batch-size=1 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailofilter function-name=hailo_yolo_inference so-path=/usr/local/lib/aarch64-linux-gnu/rpicam-apps-postproc/libyolo_hailortpp_post.so qos=false ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! hailooverlay ! queue max-size-buffers=5 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! fpsdisplaysink video-sink=ximagesink name=hailo_display sync=false text-overlay=false
