Hi guys,
I am trying to find the tutorials but they do not seem to be replicated when using the RPi (venv_hailo_rpi5_examples) virtual environment.
Is the only access for these tutorials via using a docker image?
Do you mean the Hailo Dataflow Compiler tutorials? These are about converting models into the HEF format and therefore are part of the Hailo AI Software Suite.
This software does not run on a Raspberry Pi. The Raspberry Pi can be used to run inference on a Hailo-8. For model conversion you will need a x86 PC with AVX2 support so Intel Core or equivalent AMD.
Thanks - understood
Regards
