4.19: Hailo8 does not work, Hailo8L works
Ref my previous post, with a fresh Pi5 os installation and the latest hailo 4.19 libraries:
  • I have a Hailo8 (not a Hailo8L)
    -:~/picamera2/examples/hailo $ python detect.py with default .hef I get the following warning:
    [HailoRT] [warning] HEF was compiled for Hailo8L device, while the device itself is Hailo8. This will result in lower performance.
    BUT DETECTIONS WORK
  • same program, but specifying a custom .hef compiled for Hailo8, that was working with 4.18, I don’t get the warning but I get:
    File “/home/a/picamera2/examples/hailo/detect.py”, line 20, in extract_detections
    score = detection[4]
    IndexError: invalid index to scalar variable.
Any help?
@Nadav
After long testing, I found the issue. It is not related to 8 vs 8L.
I believe it is something you have changed / fixed going from 4.18 to 4.19
that broke some existing code:
4.18:
detections = extract_detections(results[0], video_w, video_h, class_names, args.score_thresh)
4.19:
detections = extract_detections(results, video_w, video_h, class_names, args.score_thresh)
I just wish there were a place that describes the changes 4.18-4.19
Hey Thor,
I’ll investigate this error on my setup and test the fix you suggested. If the issue is related to a version change in our side, we’ll make sure to update our documentation accordingly.
Thanks for bringing this to our attention!
Note: this is a picamera2 app which is rpi software.
Best regards,
Omria
Hi, the issue was reported to Raspberry pi with the required fix. Should be updated soon in picamera2.
You can also use our detection example in GitHub - hailo-ai/hailo-rpi5-examples
