Ubuntu packages
Hi, could you please provide the hailo packages to ubuntu for raspi?
Thank you very much
Markus
Hey @markus.ploetz
You can check the instructions on how to install Hailo packages here
Regards
Hey, thanks for feedback.
“sudo apt install hailo-all” throws in Unbuntu an error “unable to locate package hailo-all”. So I thought the packages are not available in ubuntu repositories. But I may be wrong.
I’ll try to install directly from github.
Thanks Markus
Run this first
sudo apt update
sudo apt full-upgrade
I’ve done that but still have that error.
I think the packages are missing in the repo of ubuntu.
tux-desktop:~$ sudo apt update && sudo apt full-upgrade
[sudo] password for tux:
Hit:1 ubuntu-ports noble InRelease
Get:2 ubuntu-ports noble-updates InRelease [126 kB]
Hit:3 repos/code stable InRelease
Hit:4 noble-backports InRelease
Hit:5 noble-security InRelease
Fetched 126 kB in 1s (167 kB/s)
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
All packages are up to date.
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
tux-desktop:~$ sudo apt install hailo-all
E: Unable to locate package hailo-all
tux-desktop:~$ apt-cache search --names-only hailo-all
tux-desktop:~$ apt-cache search --names-only ‘hailo-all’
The packages are for raspberry os only .
If this isn’t the problem try and update to the latest os and reboot after the update all , then try again
yes, I’ve tried with raspberry os and it worked. But my main environment for raspi5 is ubuntu as both are based on debian bookworm I thought it would be possible to provide them in ubuntu repos. But I’m not really familiar with that stuff so I have to switch between systems - no problem.
Hey @markus.ploetz
The automatic installation is only on rpi os.
For ubuntu you have to install manually.
You can find all of our packages at
https://hailo.ai/developer-zone/software-downloads/
Regards
Hey, thank you.
Is a automatic installation for ubuntu planned?
I’ve downloaded
hailort-pcie-driver_4.17.0_all.deb
Unfortunatelly the manually installation failed with fresh and totally upgraded Ubuntu environment:
build-essential/noble,now 12.10ubuntu1 arm64 [installed,automatic]
Do you wish to use DKMS? [Y/n]:
dpkg: error processing package hailort-pcie-driver (–configure):
installed hailort-pcie-driver package post-installation script subprocess retur
ned error exit status 2
Errors were encountered while processing:
hailort-pcie-driver
E: Sub-process /usr/bin/dpkg returned an error code (1)
thank you
Markus
hey @markus.ploetz
For Ubuntu we have automatic docker installation.
Please run
sudo dpkg --purge hailort-pcie-driver
and then try to re-install the driver using :
sudo dpkg --install hailort-pcie-driver__all.deb
Regards
