but if i want to postprocess the output from yolov8n-obb using hailo model zoo how im suppose to integrade or modofy when there is only configuration instead no code provided or there is?
need some help over here i want to know how the alls configuration workflow and some reference on yolo postprocessing code since i believe it should be from ultralytics as i saw at hailo_sdk_client
can i get any reference how the json configuration processed? Because i know how to code a RNMS and i already did, but i have no idea how to add a rnms object to json and how the IO process
Thanks @saurabh but i was thinking yolob8n bbox decoding and yolov8n-obb bbox decoding are completely different since for the obb box decoding it need angle to find the orientation but for our case can we configured that in their bbox decoding. hmm lemme check through it. Anyways thanks for the updata @saurabh . Quite really helpful
