What's the HailoRTStatusException error mean?
Here is my code. When I run it, I get an error on the line:
with self.network_group.activate(self.network_group_params):
Does anyone know what the issue might be?
import cv2
from hailo_platform import (
    HEF, Device, VDevice, HailoStreamInterface, InferVStreams, ConfigureParams,
    InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams, FormatType
class YOLOv8_Inference_HEF:
    def __init__(self, hef_path, video_path, labels, input_resolution=(640, 640), confidence_threshold=0.5):
        self.hef_path = hef_path
        self.video_path = video_path
        self.labels = labels
        self.input_res_h, self.input_res_w = input_resolution
        self.confidence_threshold = confidence_threshold
        self.network_group = None
        self.network_group_params = None
        self.infer_pipeline = None
        self.input_vstream_info = None
    def setup_device(self):
        hef = HEF(self.hef_path)
        devices = Device.scan()
        if not devices:
            raise RuntimeError('No Devices Found')
        target = VDevice(device_id=devices)
        configure_params = ConfigureParams.create_from_hef(hef, interface=HailoStreamInterface.PCIe)
        self.network_group = target.configure(hef, configure_params)[0]
        self.network_group_params = self.network_group.create_params()
        input_vstreams_params = InputVStreamParams.make_from_network_group(self.network_group, quantized=False,
        format_type=FormatType.FLOAT32)
        output_vstreams_params = OutputVStreamParams.make_from_network_group(self.network_group, quantized=False,
        self.infer_pipeline = InferVStreams(self.network_group, input_vstreams_params, output_vstreams_params)
        self.input_vstream_info = hef.get_input_vstream_infos()[0]
    def run_Inference(self, frame):
        resized_frame = cv2.resize(frame, (self.input_res_h, self.input_res_w), interpolation=cv2.INTER_AREA)
        input_data = {
            self.input_vstream_info.name: np.expand_dims(np.asarray(resized_frame), axis=0).astype(np.float32)}
            inference_results = self.infer_pipeline.infer(input_data)
        return inference_results
    def annotate_frame(self, frame, inference_results):
        original_height, original_width, _ = frame.shape
        scale_x, scale_y = original_width / self.input_res_w, original_height / self.input_res_h
        result_key = list(inference_results.keys())[0]
        detections = inference_results[result_key][0]
        objects_positions = {'c': None, '1': None, '2': None}
        for idx, class_detections in enumerate(detections):
            if class_detections.shape[0] == 0:
                continue
            class_name = self.labels[idx]
            if class_name not in objects_positions:
                continue
            for detection in class_detections:
                confidence = detection[4]
                if confidence > self.confidence_threshold:
                    bbox_scaled = detection[0:4] * self.input_res_w
                    ymin, xmin, ymax, xmax = bbox_scaled
                    xmin, xmax = int(xmin * scale_x), int(xmax * scale_x)
                    ymin, ymax = int(ymin * scale_y), int(ymax * scale_y)
                    bbox = [xmin, ymin, xmax, ymax]
                    objects_positions[class_name] = bbox
                    center_x = int((xmin + xmax) / 2)
                    center_y = int((ymin + ymax) / 2)
                    cv2.circle(frame, (center_x, center_y), 20, (0, 255, 255), thickness=-1)
                    frame = cv2.putText(frame, class_name, (center_x, center_y), cv2.FONT_HERSHEY_SIMPLEX, 1,
                                        (0, 255, 0), 1, cv2.LINE_AA)
        if objects_positions['c'] is not None and objects_positions['1'] is not None:
            center_line_x, center_line_y = int((objects_positions['c'][0] + objects_positions['c'][2]) / 2), \
                int((objects_positions['c'][1] + objects_positions['c'][3]) / 2)
            obj1_x, obj1_y = int((objects_positions['1'][0] + objects_positions['1'][2]) / 2), \
                int((objects_positions['1'][1] + objects_positions['1'][3]) / 2)
            frame = cv2.line(frame, (center_line_x, center_line_y), (obj1_x, obj1_y), (255, 0, 0), 1)
        return frame
    def process_video(self):
        cap = cv2.VideoCapture(self.video_path)
        while cap.isOpened():
            start_time = cv2.getTickCount()
            ret, frame = cap.read()
            if not ret:
                break
            inference_results = self.run_Inference(frame)
            frame = self.annotate_frame(frame, inference_results)
            end_time = cv2.getTickCount()
            time_interval = (end_time - start_time) / cv2.getTickFrequency()
            fps = 1.0 / time_interval
            print(f'FPS = {fps:.2f}')
            cv2.imshow('Inference', frame)
                break
        cap.release()
        cv2.destroyAllWindows()
def main():
    labels = ['c', '1', '2']
    video_path = '1plus_cut_264.mp4'
    hef_path = 'yolov8n.hef'
    yolo_inference = YOLOv8_Inference_HEF(hef_path, video_path, labels)
    yolo_inference.setup_device()
    yolo_inference.process_video()
if __name__ == '__main__':
    main()
Hey @Yen,
Could you please provide more details about the error you encountered? Having specifics will help me better understand and troubleshoot the issue.
Hi @omria , I have fixed the error in my code, but I found that the detection results from Hailo are not as expected and are quite poor. However, when I use the official GitHub repository “hailo-rpi5-examples,” the inference works correctly and gives accurate results. Could you please check if my program is missing any steps?
import cv2
    InputVStreamParams, OutputVStreamParams, FormatType
        self.input_vstreams_params = None
        self.output_vstreams_params = None
        self.target = None
        if not devices:
        self.target = VDevice(device_ids=devices)
        self.network_group = self.target.configure(hef, configure_params)[0]
        self.input_vstreams_params = InputVStreamParams.make_from_network_group(self.network_group, quantized=False,
        self.output_vstreams_params = OutputVStreamParams.make_from_network_group(self.network_group, quantized=False,
        input_data = {
        with InferVStreams(self.network_group, self.input_vstreams_params, self.output_vstreams_params) as infer_pipeline:
                inference_results = infer_pipeline.infer(input_data)
        pC, holes = None, []
                continue
                    if class_name == 'center':
                        pC = bbox
                    elif class_name == 'hole':
                        holes.append(bbox)
                    cv2.circle(frame, (center_x, center_y), 20, (0, 255, 255), thickness=3)
        if pC:
            p0x, p0y = int((pC[0] + pC[2]) / 2), int((pC[1] + pC[3]) / 2)
            top_left_hole = None
            tolerance = 200
            for hole in holes:
                p1x, p1y = int((hole[0] + hole[2]) / 2), int((hole[1] + hole[3]) / 2)
                offset_x = p1x - p0x
                offset_y = p1y - p0y
                if offset_x <= tolerance and offset_y < tolerance:
                    if top_left_hole is None or p1x < (top_left_hole[0] + top_left_hole[2]) / 2:
                        top_left_hole = hole
            if top_left_hole:
                p1x, p1y = int((top_left_hole[0] + top_left_hole[2]) / 2), int(
                    (top_left_hole[1] + top_left_hole[3]) / 2)
                start_point = (p0x, p0y)
                end_point = (p1x, p1y)
                cv2.line(frame, start_point, end_point, (255, 0, 0), 3)
        return frame
            if not ret:
                break
                break
        cap.release()
    def __del__(self):
        if self.target:
            self.target.release()
def main():
    labels = ['center', 'hole']
    video_path = 'videos/Papilla #1+_241204_new_capture_3.mkv'
    hef_path = 'yolov8n_ver_0_0_1.hef'
    main()
and why does the FPS drop by half when not using GStreamer?
Using the GStreamer example code, the FPS can reach 60, but when I run this code, its accuracy is not as good as GStreamer, and the FPS drops to 30.
Does anyone know why?
