Hello.
I’ve noticed discrepancy in the order of input/output vectors between the output of hailoclirt parse-hef <model>.hef
and of hailort::InferVStreams.get_input_vstreams()
For example, on the tiny_yolov4_license_plates.hef
model I get this from hailortcli parse-hef
Network group name: tiny_yolov4_license_plates, Single Context
Network name: tiny_yolov4_license_plates/tiny_yolov4_license_plates
VStream infos:
Input tiny_yolov4_license_plates/input_layer1 UINT8, NHWC(416x416x3)
Output tiny_yolov4_license_plates/conv19_centers UINT8, NHWC(13x13x6)
Output tiny_yolov4_license_plates/conv19_scales UINT8, NHWC(13x13x6)
Output tiny_yolov4_license_plates/conv19_obj UINT8, NHWC(13x13x3)
Output tiny_yolov4_license_plates/conv19_probs UINT8, NHWC(13x13x3)
Output tiny_yolov4_license_plates/conv21_centers UINT8, NHWC(26x26x6)
Output tiny_yolov4_license_plates/conv21_scales UINT8, NHWC(26x26x6)
Output tiny_yolov4_license_plates/conv21_obj UINT8, NHWC(26x26x3)
Output tiny_yolov4_license_plates/conv21_probs UINT8, NHWC(26x26x3)
and from the following example code
for (const auto &input_vstream : (*pipeline).get_input_vstreams())
auto frame_size = input_vstream.get().get_frame_size();
uint8_t *ptr = func(frame_size); //allocate memory
input_data_mem_views.emplace(input_vstream.get().name(), hailort::MemoryView((void *)ptr, frame_size));
std::cout << "Adding input layer " << input_vstream.get().name() << " of size " << frame_size << std::endl;
current_input_vector++;
for (const auto &output_vstream : (*pipeline).get_output_vstreams())
auto frame_size = output_vstream .get().get_frame_size();
input_data_mem_views.emplace(output_vstream.get().name(), hailort::MemoryView((void *)ptr, frame_size));
std::cout << "Adding input layer " << output_vstream .get().name() << " of size " << frame_size << std::endl;
I get
Adding input layer tiny_yolov4_license_plates/input_layer1 of size 519168
Adding output layer tiny_yolov4_license_plates/conv19_centers of size 1014
Adding output layer tiny_yolov4_license_plates/conv19_obj of size 507
Adding output layer tiny_yolov4_license_plates/conv19_probs of size 507
Adding output layer tiny_yolov4_license_plates/conv19_scales of size 1014
Adding output layer tiny_yolov4_license_plates/conv21_centers of size 4056
Adding output layer tiny_yolov4_license_plates/conv21_obj of size 2028
Adding output layer tiny_yolov4_license_plates/conv21_probs of size 2028
Adding output layer tiny_yolov4_license_plates/conv21_scales of size 4056
This is causing problems in my application because I have one process using hailortcli to figure how the total space needed for the input/output vectors, allocating their memory and passing pointers to those vectors to the process that actually posesses the vDevice and performs the inference. This obviously causes issues has the inference process goes out of bound, in this case on the last vector.
My original approach was to temporarily create a vDevice to use get_output_vstreams
to load the vectors dimensions, but I can’t do that as the HAILO8 device is already taken by the inference process. I don’t have the hailort-service
, as I really dont need it, I only have one inference process.
Why is there this discrepancy between hailortcli parse-hef
and how the vectors are ordered in the std::map
of MemoryView
Thanks.
