Hello Hailo Community,
I am seeking assistance with a persistent issue encountered while attempting to compile the distil-whisper/distil-small.en model for a Hailo-8L accelerator. The goal is to deploy a low-latency speech-to-text model for an embedded voice assistant project.
Methodology: The model was sourced from Hugging Face and exported to ONNX format using the recommended optimum-cli tool. The compilation is being attempted with the Hailo AI Software Suite (DFC Version 3.31.0) running within its official Docker container on a WSL2 host.
The Core Issue: The process fails during the parsing stage when running hailo parser onnx. Despite numerous attempts with different command-line flags, the process consistently terminates with the following error:
hailo_sdk_common.hailo_nn.exceptions.UnsupportedModelError: Invalid kernel shape for base conv layer base_conv1 (translated from /conv1/Conv).
This strongly suggests the Dataflow Compiler is struggling to interpret the initial 1D Convolutional layer in the Whisper encoder’s architecture, which is fundamental to how it processes audio spectrograms.
Troubleshooting Steps Performed: To resolve this, I have exhaustively tried to guide the parser by:
- Explicitly defining the input tensor name and shape using the
--tensor-shapesflag. - Explicitly defining the graph boundaries using
--start-node-namesand--end-node-namesflags.
Unfortunately, none of these steps have resolved the underlying UnsupportedModelError. Furthermore, a review of the included Hailo Model Zoo for this SDK version shows no available models for Speech-to-Text or ASR tasks.
My Questions for the Community:
- Has anyone successfully compiled a Whisper-family model, or any audio model with initial 1D convolutions, for the Hailo-8L?
- Is there a known workaround, a required ONNX graph modification (“model surgery”), or a specific compilation recipe (YAML configuration) that can resolve this incompatibility with 1D Conv layers?
- Does a newer version of the Hailo SDK offer improved support for these audio-centric architectures or include a pre-configured ASR model?
Any guidance, insights, or successful workflows from the community would be immensely appreciated.
Error :"(hailo_virtualenv) hailo@docker-desktop:/local/shared_with_docker/whisper_onnx$ hailo parser onnx encoder_model.onnx --tensor-shapes ‘input_features=[1,80,3000]’ --start-node-names input_features --end-node-names last_hidden_state
[info] Current Time: 07:06:01, 07/09/25
[info] CPU: Architecture: x86_64, Model: 13th Gen Intel(R) Core™ i7-13650HX, Number Of Cores: 20, Utilization: 0.1%
[info] Memory: Total: 17GB, Available: 16GB
[info] System info: OS: Linux, Kernel: 6.6.87.2-microsoft-standard-WSL2
[info] Hailo DFC Version: 3.31.0
[info] HailoRT Version: 4.21.0
[info] Running hailo parser onnx encoder_model.onnx --tensor-shapes input_features=[1,80,3000] --start-node-names input_features --end-node-names last_hidden_state
[info] Translation started on ONNX model encoder_model
[info] Restored ONNX model encoder_model (completion time: 00:00:06.08)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:11.51)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:44.24)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 239, in translate_onnx_model
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 320, in _parse_onnx_model_to_hn
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 371, in parse_model_to_hn
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py”, line 92, in convert_model
self._calculate_shapes(validate_shapes=False)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 207, in _calculate_shapes
self._layers_graph.calculate_shapes(meta_edges_graph=self._meta_graph, validate_shapes=validate_shapes)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py”, line 761, in calculate_shapes
self.update_input_shapes_from_predecessors(layer)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py”, line 826, in update_input_shapes_from_predecessors
layer.input_shapes = input_shapes
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py”, line 541, in input_shapes
self.set_input_shapes(input_shapes)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/conv2d.py”, line 565, in set_input_shapes
raise UnsupportedModelError(
Either the input shape doesn’t match the kernel shape, or the calculated groups number doesn’t match the expected ratio between kernel shape and input shape.
Kernel features: 80 Input features: 3000 Groups: 37
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py”, line 213, in run
self._parse(net_name, args, tensor_shapes)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py”, line 297, in _parse
self.runner.translate_onnx_model(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1187, in translate_onnx_model
parser.translate_onnx_model(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 280, in translate_onnx_model
File “/local/workspace/hailo_virtualenv/bin/hailo”, line 8, in
sys.exit(main())
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py”, line 111, in main
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py”, line 64, in run
return self._run(argv)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py”, line 104, in _run
return args.func(args)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py”, line 237, in run
raise ParserCLIException(str(err).replace(“net_input_format”, “input_format”)) from err
hailo_sdk_client.tools.parser_cli.ParserCLIException: Invalid kernel shape for base conv layer base_conv1 (translated from /conv1/Conv).
Kernel features: 80 Input features: 3000 Groups: 37"
