I am attempting to test if I can run a language model, or it can even be a different kind of model, on the Raspberry Pi AI kit. I can not seem to find a good guide to do this conversion, do you know of one?
The only one I found so far was with hailo model zoo, but it only applies to a list of models, not any model.
Currently, the Hailo-8 doesn’t support LLMs directly. The Hailo-8 is specifically designed for edge AI applications, with its primary strength being computer vision tasks like object detection, image classification, and segmentation.
Let me explain why running LLMs on Hailo-8 is challenging:
The Hailo-8 isn’t ideal for LLMs because:
These models require substantial memory and computing power
The Hailo-8’s architecture and Model Zoo are optimized for vision tasks, not language processing
The platform has specific memory and bandwidth limitations that make it unsuitable for large models
However, here are some alternatives you might consider:
You could try working with smaller, compressed transformer models like DistilBERT or TinyBERT, though this would need significant adaptation for Hailo compatibility.
Consider a hybrid approach where you use:
Hailo-8 for handling pre/post-processing tasks
A separate processor (CPU/GPU) for running the actual LLM inference
If you’re specifically interested in language models and more complex AI tasks, you might want to look into the Hailo-10H, which is better equipped for such workloads.
The platform may expand to support LLMs in future releases, but for now, I’d recommend focusing on vision-based applications with the Hailo-8.
Feel free to ask if you need more specific guidance!
