compile ONNX model to HEF model costs about 2 hours.
is that normal?
Is there any way to reduce time?
Hi @wangzongzheng unrelated to your question. But how did you get the conversion to work? i am trying to convert superpoint model from onnx to HEF.
Check this thread
Are you sure that you have GPU available?
In addition, are you using Docker based solution?
I’ve compiling onnx to have without --performance for around 20-30 mins.
With the performance flag is can be up to 5 hours.
succeeded in generating the .hef file. Made an inferende script in python. Now stuck at the hailort module not being recognized.
Environment Setup:
I am using pyenv to manage Python versions, with a virtual environment hailoconv set to Python 3.10.4.
The environment is activated successfully (pyenv activate hailoconv), and I have verified this by running python --version (which shows Python 3.10.4).
hailort Installation:
I installed hailort version 4.20.0 appropriate for python 3.10 using .whil file hailort-4.20.0-cp310-cp310-linux_aarch64.whl. Suitable for my system arch.
Confirmed the installation with pip show hailort, which shows that version 4.20.0 is installed in the correct path:
/home/my/.pyenv/versions/3.10.4/envs/hailoconv/lib/python3.10/site-packages.
Issue Encountered:
Despite the successful installation of hailort, when I attempt to import the module in Python (import hailort), I receive the following error:
ModuleNotFoundError: No module named 'hailort'
I verified the Python executable being used with which python, which correctly points to
/home/my/.pyenv/versions/3.10.4/envs/hailoconv/bin/python
I have tried importing the module directly in a Python session using the following:
import hailort
But it still returns the ModuleNotFoundError.
Attempts to Resolve:
I have tried deactivating and reactivating the environment (pyenv deactivate / pyenv activate hailoconv).
Reinstalled hailort by running pip uninstall hailort followed by pip install hailort.
Checked the PYTHONPATH environment variable and ensured it includes the correct path to the site-packages directory for the virtual environment.
Apologies if inapropriate to post this here!!
