Unable to install Hailort and Hailofw v4.18.0
For Rasbperry Pi 5:
Also remember before installing the PCIE driver with the command
sudo dpkg --install hailort-4.18.0-cp311-cp311-linux_aarch64.whl
Install these dependencies (otherwise it will fail to install with DKMS:
sudo apt install bison flex libelf-dev dkms build-essential
Reboot and run:
you should get something similar to:
Identifying board
Control Protocol Version: 2
Firmware Version: 4.18.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB241600804
Part Number: HM21LB1C2LAE
Did this on a clean install following the guidance of the Developer Zone documentation
I get the same issue, can you fix it?
