Ubuntu 22.04 installation not working
Hi folks,
Im attempting to install hailoRT alongside the relevant drivers from the developer zone found here:
https://hailo.ai/developer-zone/software-downloads/
Im running a local (dualboot) of Ubuntu 22.04 with the following hardware specs:
Intel Core i7-13800H
NVIDIA RTX-4070 Laptop GPU
Hailo 8 Processor Connected through an Envoy express thunderbolt 4 adapter.
I keep running into a failure to install the pcie driver, In another post mentioned here:
It was mentioned that a specific kernel version is required in order to install the pcie driver, and since im not certain if this is actually the case, this is my kernel specifications
0 : menuentry 'Ubuntu, with Linux 6.8.0-48-generic' --class ubuntu
1 : menuentry 'Ubuntu, with Linux 6.8.0-48-generic (recovery mode)'
2 : menuentry 'Ubuntu, with Linux 6.8.0-40-generic' --class ubuntu
3 : menuentry 'Ubuntu, with Linux 6.8.0-40-generic (recovery mode)'
Is there a clearer installation guide perhaps? i followed the installation guide from the website step by step and keep running into the same error.
Cheers, and looking forward to hearing back,
Hey @_yonatan
What version of the driver and the HailoRT are you trying to install?
4.18 doesn’t support 6.8 kernel version only 6.5 and under , in 4.19 version this issue is solved
Regards
Hi again,
Thanks for the quick response,
Just updating here that I upgraded to version 4.19 and everything seems to work just fine,
Cheers,
