I have been trying to perform inferencing with csv file as an input but compared to when images are taken as an input, using csv is is very slow.
what can be the reason?
Following is the code that I am using.
import os
import glob
from hailo_platform import __version__
from multiprocessing import Process, Queue, Manager
from hailo_platform import (HEF, Device, VDevice, HailoStreamInterface, ConfigureParams,
InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams, FormatType)
from zenlog import log
import time
import argparse
import csv
import cProfile
import pstats
from io import StringIO
# Set up argument parser
parser = argparse.ArgumentParser(description='Running a Hailo inference using CSV input')
parser.add_argument('hef', help="HEF file path")
parser.add_argument('--input-dir', help="Directory path containing CSV files for classification.")
parser.add_argument('--output-csv', default="inference_results.csv", help="Path to save all results as a single CSV file.")
args = parser.parse_args()
# ---------------- Post-processing function ----------------- #
def post_processing(inference_output, sample_name, results_list):
class_probabilities = inference_output[0] # Assuming a single output with class probabilities
predicted_class = np.argmax(class_probabilities) # Get the index of the highest probability
confidence = class_probabilities[predicted_class]
# Append the result to the results list
results_list.append([sample_name, predicted_class, confidence])
# ---------------- Inference threads functions -------------- #
def send(configured_network, csv_data, num_samples, batch_size=100):
vstreams_params = InputVStreamParams.make_from_network_group(configured_network, quantized=False, format_type=FormatType.FLOAT32)
configured_network.wait_for_activation(100)
print('Performing classification on CSV data...\n')
with InputVStreams(configured_network, vstreams_params) as vstreams:
for i in range(0, num_samples, batch_size):
batch_data = csv_data[i:i + batch_size]
for vstream in vstreams:
batch_data_expanded = np.expand_dims(batch_data, axis=0).astype(np.float32)
vstream.send(batch_data_expanded)
def recv(configured_network, write_q, num_samples, batch_size=100, max_retries=5):
vstreams_params = OutputVStreamParams.make_from_network_group(configured_network, quantized=False, format_type=FormatType.FLOAT32)
with OutputVStreams(configured_network, vstreams_params) as vstreams:
for _ in range(0, num_samples, batch_size):
curr_vstream_data_dict = {}
retry_count = 0
while retry_count <= max_retries:
try:
data = vstream.recv()
if data.ndim == 1:
curr_vstream_data_dict[vstream.name] = data
else:
raise ValueError(f"Unexpected data shape: {data.shape}")
break # Exit the retry loop if successful
except hailo_platform.pyhailort.pyhailort.HailoRTTimeout:
retry_count += 1
if retry_count > max_retries:
log.error(f"Max retries exceeded for vstream {vstream.name}.")
raise
else:
log.warning(f"Timeout on vstream {vstream.name}. Retrying {retry_count}/{max_retries}...")
time.sleep(2 ** retry_count) # Exponential backoff
write_q.put(curr_vstream_data_dict)
def inference(read_q, sample_names, current_file_index, total_files, num_samples, results_list):
i = 0
while i < num_samples:
if not read_q.empty():
inference_dict = read_q.get(0)
inference_output = list(inference_dict.values())
print(f"Processing sample {sample_names[i]} (File {current_file_index}/{total_files})") # Updated logging
post_processing(inference_output, sample_names[i], results_list)
i += 1
# ---------------- Pre-processing CSV data ------------------ #
def preprocess_csv_data(csv_file_path, expected_size):
csv_data = []
sample_names = []
with open(csv_file_path, newline='') as csvfile:
csvreader = csv.reader(csvfile)
for i, row in enumerate(csvreader):
if len(row) != 1:
raise ValueError(f"Row {i+1} in CSV file should have exactly one value. Found: {len(row)} values.")
sample_data = float(row[0].strip()) # Trim whitespace and convert to float
csv_data.append(sample_data)
sample_names.append(f'Sample_{i+1}_{os.path.basename(csv_file_path)}')
csv_data = np.array(csv_data, dtype=np.float32).reshape(-1, expected_size) # Reshape to (num_samples, expected_size)
return csv_data, sample_names
# ---------------- Save results to CSV file ----------------- #
def save_results_to_csv(results_list, output_csv_path="inference_results.csv"):
if results_list:
with open(output_csv_path, mode='w', newline='') as file:
writer = csv.writer(file)
writer.writerow(["Sample Name", "Predicted Class", "Confidence"])
writer.writerows(results_list)
print(f'Results saved to {output_csv_path}')
else:
print("No results to save.")
# ---------------- Start of the script --------------------- #
def main():
hef = HEF(args.hef)
height, width, channels = hef.get_input_vstream_infos()[0].shape
num_features = 200 # Overriding to match expected input size
# Get all CSV files and limit to 1000
csv_files = glob.glob(f"{args.input_dir}/*.csv")
csv_files = csv_files[:1000] # Limit to the first 1000 files
total_files = len(csv_files) # Update the total number of CSV files
# Use a Manager to create a shared list for results
with Manager() as manager:
results_list = manager.list() # Use a managed list
devices = Device.scan()
with VDevice(device_ids=devices) as target:
configure_params = ConfigureParams.create_from_hef(hef, interface=HailoStreamInterface.PCIe)
queue = Queue()
# Preprocess each CSV file
for file_index, csv_file in enumerate(csv_files, start=1): # Start the index at 1
csv_data, sample_names = preprocess_csv_data(csv_file, num_features)
num_samples = csv_data.shape[0]
send_process = Process(target=send, args=(network_group, csv_data, num_samples, 100))
recv_process = Process(target=recv, args=(network_group, queue, num_samples, 100))
inference_process = Process(target=inference, args=(queue, sample_names, file_index, total_files, num_samples, results_list))
start_time = time.time()
recv_process.start()
send_process.start()
inference_process.start()
with network_group.activate():
recv_process.join()
send_process.join()
inference_process.join()
end_time = time.time()
print(f'Processed file {csv_file} in {end_time - start_time:.3f} seconds')
