Running inference shows COCO classes
Hello everyone! Using hailo dataflow compiler, i converted my .onnx model to a .hef, tested inference and it works. The issue is that the labels of the bounding boxes are from COCO dataset, and not my own.
I used hailo’s CLI commands to parse, optimize and compile, what did i miss?
Hey @Alexandru_Ont ,
This might be one of two things:
1- You didn’t include it in the compilation process.
2- You don’t include it in the run process of the model!
Thanks for the response! But i do have another question now, how can i include it in the compilation or in the run process?
I have looked into what i can give as an argument to compiler, except model script i did not see anything suggesting the possibility to give labels as json or something. And at inference, i have a hailo_yolov8_inference.json where i load the .hef model, where do i specify labels at this stage?
