Run "hailortcli fw-control identify" will show error messages in windows 11 for hailo-8l
I’m working on windows 11 home edition and have installed hailort_4.19.0_windows_installer.
After installed hailort, “hailortcli scan” seems works fine but “hailortcli fw-control identify” will show some error messages.
C:\Windows\System32>hailortcli scan
Hailo Devices:
[-] Device: 0000:01:00.0
C:\Windows\System32>hailortcli fw-control identify
[HailoRT] [warning] FW is not loaded to the device. Please load FW before using the device.
[HailoRT] [error] CHECK failed - Failed in fw_control, errno:1359
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_FW_CONTROL_FAILURE(18) - Failed to send fw control
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_FW_CONTROL_FAILURE(18) -
Failed to execute on device: 0000:01:00.0. status= HAILO_FW_CONTROL_FAILURE(18)
Does this mean that hailort/pcie driver installed failed?
Thx
Yen
Can you please try running a model using the HailoRT CLI?
hailortcli run model.hef
If you do not have a HEF file at hand you can download one from the Hailo Model Zoo.
GitHub - Hailo Model Zoo - Public Models
It works on hailort_4.18.0_windows_installer.
4.19 is not working.
Thx
Yen
