Hailortcli fw-control identify not returning anything
I had hailo 4.20 installed on my raspberry pi 5, but it had some issues with hailo-rpi5-examples, which required me to use 4.19. I tried completely uninstalling hailo, removed all halo related directories and files, and removed everything hailo related from ~/.bashrc. Then, I tried reinstalling it, both with
sudo apt install hailo-tappas-core=3.30.0-1 hailo-dkms=4.19.0-1 hailort=4.19.0-3
to install hailo 4.19, and
sudo apt install hailo-all
Before each time I completely removed hailo, and started with a fresh installation, and both times running
returned nothing at all.
I did not try this on the first reinstallation attempt, but on the second I also tried
dmesg | grep -i hailo
which returned
[ 2.358289] hailo: Init module. driver version 4.20.0
[ 2.358365] hailo 0000:01:00.0: Probing on: 1e60:2864…
[ 2.358368] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 13184
[ 2.358380] hailo 0000:01:00.0: enabling device (0000 → 0002)
[ 2.358385] hailo 0000:01:00.0: Probing: Device enabled
[ 2.358400] hailo 0000:01:00.0: Probing: mapped bar 0 - 0000000092794423 16384
[ 2.358405] hailo 0000:01:00.0: Probing: mapped bar 2 - 000000005966366f 4096
[ 2.358407] hailo 0000:01:00.0: Probing: mapped bar 4 - 0000000065d73ea7 16384
[ 2.358411] hailo 0000:01:00.0: Probing: Setting max_desc_page_size to 16384, (page_size=16384)
[ 2.358418] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 2.358420] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[ 2.358423] hailo 0000:01:00.0: Disabling ASPM L0s
[ 2.358426] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 2.358492] hailo 0000:01:00.0: Writing file hailo/hailo8_fw.bin
[ 2.362404] Failed to write file hailo/hailo8_fw.bin
[ 2.362412] hailo 0000:01:00.0: Failed writing NNC firmware files. err -2
[ 2.362415] hailo 0000:01:00.0: FW loaded, took 3 ms
[ 2.362474] hailo 0000:01:00.0: Firmware load failed
[ 2.362476] hailo 0000:01:00.0: Failed activating board -2
[ 2.362492] hailo: probe of 0000:01:00.0 failed with error -2
I don’t know what to do, and I don’t want to have to wipe my SD card and re-flash RPi OS.
I’m not entirely sure what I did, but it is working fine now. It may have just needed a power cycle.
Hey @joshhtgould,
Usually we run reboot right after running the installation. In your case, the Max_desc_page_size wasn’t set because the driver wasn’t up (my guess). Happy to hear it worked!
