Hi Hailo Team,
I successfully trained a custom YOLOv5s model (1 class: barcode
) and compiled it into a .hef
using the Hailo Model Zoo pipeline with NMS enabled (nms: true
in YAML). The .hef
runs fine on my Raspberry Pi 5:
Model sanity check:
hailortcli run /home/jcyen/.../custom_yolov5s.hef
Output:
FPS: 123.37
Frames count: 617
Recv Rate: 6.39 Mbit/s
→ This shows the model is functional.
Problem:
- Video plays
- Frame count increases (e.g.,
Frame count: 409
) - No error
- But no detections are printed or drawn
Details:
.json
file follows Hailo schema:
"labels": ["barcode"],
"num_classes": 1,
"meta_arch": "yolo_v5",
"device_pre_post_layers": { "nms": true }
- Model trained with image size 640x640
- Tested on video where barcodes are clearly visible
What I suspect:
- NMS config not applied correctly?
- Bounding box size out of frame?
- Postprocess lib mismatch?
I would really appreciate your help—everything runs but detection results never show up. Thanks a lot!
