Revert to Hailo 4.19 on Raspberry Pi with Hailo 8L?
Ive been running Frigate 0.15.0 since beta 1 and it worked perfectly, I then accidentally updated my Pi and the Hailo sw got pushed up to 4.20.1 and now Frigate 0.15.0 doesnt work.
I have tried the “fixes” on the Frigate discussion several times but cannot get it to work.
It consistently shows the “failure” driver version and library version are not in sync.
Is there anyway to just install and run the 4.19 software that is compatible with Frigate 0.15?
Have a look at the following page section Alternative Package Versions.
Raspberrypi - Documentation - AI
Thanks, I had seen that, it only offers 4.18, and 4.17. I need 4.19, if possible.
Hi, here are the instruction for downgrading to 4.19.
It will be updated in rpi documentation soon.
sudo apt install hailo-tappas-core=3.30.0-1 hailort=4.19.0-3 hailo-dkms=4.19.0-1 python3-hailort=4.19.0-2
Thank you!
Very appreciated
