Hello, I am trying to implement a cascaded YOLO detection → ReID tracking pipeline using the guidance from:
TAPPAS Guide 3.1.6 (Face Detection & Landmarking pipeline)
TAPPAS Guide 5.1.0 (Cascaded Networks Structure)
Hailo blog : User Guide 3: Simplifying Object Detection on a Hailo Device Using DeGirum PySDK
My environment uses HEF models from Hailo Model Zoo
Executing on device: 0001:01:00.0 Identifying board Control Protocol Version: 2 Firmware Version: 5.0.0 (release,app) Logger Version: 0 Device Architecture: HAILO10H
hailortcli parse-hef /home/ysj/7_reID_YJI/models/repvgg_a0_person_reid_512.hef
Architecture HEF was compiled for: HAILO15H Network group name: repvgg_a0_person_reid_512, Single Context Network name: repvgg_a0_person_reid_512/repvgg_a0_person_reid_512 VStream infos: Input repvgg_a0_person_reid_512/input_layer1 UINT8, NHWC(256x128x3) Output repvgg_a0_person_reid_512/fc1 UINT8, NC(512)
hailortcli parse-hef /home/ysj/7_reID_YJI/models/yolov8m.hef
Architecture HEF was compiled for: HAILO15H Network group name: yolov8m, Multi Context - Number of contexts: 5 Network name: yolov8m/yolov8m VStream infos: Input yolov8m/input_layer1 UINT8, NHWC(640x640x3) Output yolov8m/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 80, maximum bounding boxes per class: 100, maximum frame size: 160320) Operation: Op YOLOV8 Name: YOLOV8-Post-Process Score threshold: 0.200 IoU threshold: 0.70 Classes: 80 Max bboxes per class: 100 Image height: 640 Image width: 640
I attempted to build a pipeline:
#!/usr/bin/env bash
set -euo pipefail
# YOLO → ReID
YOLO_HEF=/home/…/yolov8m.hef
YOLO_POST_SO=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/libyolo_hailortpp_post.so
YOLO_FUNC=yolov8m
REID_HEF=/home/…/repvgg_a0_person_reid_512.hef
REID_POST_SO=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/libre_id.so
REID_FUNC=filter
CROP_POST_SO=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/cropping_algorithms/libdetection_croppers.so
CROP_FUNC=all_detections
#CROP_POST_SO=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/cropping_algorithms/libre_id.so
#CROP_FUNC=track_counter # create_crops
DBUG_POST_SO=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/libdebug.so
DBUG_FUNC=dump_tensors_to_npy # print_roi_bboxs dump_tensors_to_npy filter identity sleep10
VIDEO_DEV=/dev/video0
QUEUE=“leaky=downstream max-size-buffers=30 max-size-bytes=0 max-size-time=0”
SCHED=“scheduling-algorithm=1 vdevice-group-id=group1”
CROPPER=“internal-offset=true drop-uncropped-buffers=true use-letterbox=true”
VIDEO=“framerate=30/1,interlace-mode=progressive,pixel-aspect-ratio=1/1”
DBUG=“hailofilter so-path=$DBUG_POST_SO function-name=$DBUG_FUNC qos=false ! queue $QUEUE !”
YOLO_PIPELINE=“videoscale ! video/x-raw,format=RGB,height=640,width=640,$VIDEO !
queue $QUEUE !
hailonet name=YOLO hef-path=$YOLO_HEF $SCHED !
queue $QUEUE !
hailofilter so-path=$YOLO_POST_SO function-name=$YOLO_FUNC qos=false !
queue $QUEUE !
hailotracker class-id=1 debug=true !
queue $QUEUE”
REID_PIPELINE=“videoconvert ! videoscale ! video/x-raw,format=RGB,height=256,width=128,$VIDEO !
queue $QUEUE !
hailonet name=REID hef-path=$REID_HEF $SCHED !
queue $QUEUE”
GST_DEBUG=3 gst-launch-1.0 -ev
v4l2src device=$VIDEO_DEV ! videoconvert !
tee name=t hailomuxer name=hmux
t. ! queue $QUEUE ! hmux.
t. ! $YOLO_PIPELINE ! hmux.
hmux. ! queue $QUEUE !
hailocropper name=cropper so-path=$CROP_POST_SO function-name=$CROP_FUNC $CROPPER
hailoaggregator name=agg
cropper.src_0 ! queue $QUEUE ! agg.sink_0
cropper.src_1 ! $REID_PIPELINE ! $DBUG agg.sink_1
agg. ! hailofilter so-path=$REID_POST_SO function-name=$REID_FUNC qos=false ! queue $QUEUE !
hailooverlay local-gallery=true ! videoconvert !
fpsdisplaysink video-sink=xvimagesink name=hailo_display sync=false text-overlay=true
The strange issue is:
1. ReID embeddings ARE being generated
I can confirm that the ReID post-process runs.
Debug output shows
“repvgg_a0_person_reid_512_fc1.npy”embedding files saved for each detection.
2. But all bounding boxes become a single red color
No unique color per ID
No identity text (ID number) shown
Only “tracked” / “lost” labels appear (only hailotracker behavior)
3. Even though ReID is connected, the output looks identical to standalone hailotracker
The tracking is NOT improved by appearance embeddings
The result is completely different from what a true ReID-based tracker should produce
4. If I remove hailotracker, YOLO results appear normally
(no ReID, no IDs, only basic detection boxes)
5. I expected:
Consistent IDs (e.g., ID1, ID2…)
Colored boxes per ID
Appearance-based re-assignment between frames
But instead I only see:
“tracked/new/lost” labels from hailotracker
No IDs
No color differentiation
All boxes red
My suspicion
It seems like:
repvggdoes generate embeddings,
but does NOT output them in the tensor format thatlibre_id.soexpects,
OR -
My cascaded hailofilter order/connection is incorrect,
OR -
The
.npyoutputs mean embeddings exist,
but they are not being passed forward on the buffer metadata,
solibre_id.sois ignoring them.
I could not find documentation describing the exact required format for libre_id.so to consume custom ReID embeddings, so I am unsure whether my pipeline is correct.
My Questions
In a cascaded network, what is the correct way to pass ReID embeddings to
libre_id.so?- Is there a required tensor name or metadata field?
Does hailotracker expect a specific tensor layout for embeddings
(e.g.,hailo_emborembedding_vector)? -
Why does hailooverlay show only red boxes and no IDs even though embeddings exist?
Any help would be greatly appreciated
If needed I can upload:
Full GStreamer pipeline command
Logs
Screenshots
Example
.npyembeddings
Thank you very much in advance for your time and guidance!
