Questions about Output Shapes and NMS Config in yolov8n.onnx -> hef Conversion
When converting yolov8n.onnx to hef with the following NMS configuration options:
[yolov8n_nms_config.json]
    "nms_scores_th": 0.3,
    "nms_iou_th": 0.7,
    "image_dims": [
        640,
        640
    "max_proposals_per_class": 25,
    "classes": 1,
    "regression_length": 16,
    "background_removal": false,
    "bbox_decoders": [
            "name": "bbox_decoder41",
            "stride": 8,
            "reg_layer": "conv41",
            "cls_layer": "conv42"
            "name": "bbox_decoder52",
            "stride": 16,
            "reg_layer": "conv52",
            "cls_layer": "conv53"
            "name": "bbox_decoder62",
            "stride": 32,
            "reg_layer": "conv62",
            "cls_layer": "conv63"
When checking the output shape of the converted yolov8n.hef model using hailort (C++), the output shape is (1, 80, 25, 2000). However, when checking the output shape using the hailo profiler (model.har), it shows (80, 5, 25).
I have two questions:
  1. Setting aside the reshape, why is there memory allocated for 2000?
  2. When applying the NMS config option in yolov8n, how is bbox decoding supposed to be done from the output?
Thank you for your help.
Hey @Ohjun_Kwon,
Regarding Q1 - The 2000 dimension explanation:
The 2000 you’re seeing is the result of your NMS configuration being set to 80 classes with 25 maximum detections per class (80 × 25 = 2000 total detection slots).
While your JSON shows "classes": 1, the tensor dimensions indicate the model was compiled with the standard 80-class COCO configuration. This suggests either:
  • The JSON configuration wasn’t properly applied during model compilation
  • You’re referencing a different model file than intended
The tensor layout (1, 80, 25, 2000) represents:
  • Logical structure: [num_classes, attributes_per_detection, max_detections_per_class]
  • The 5 attributes per detection: [x_min, y_min, x_max, y_max, confidence_score]
  • The 2000 represents the flattened total allocation in the physical memory layout
Verification step: A properly compiled model with classes: 1 and max_proposals_per_class: 25 should yield dimensions totaling 125 (1×5×25). The presence of 2000 indicates the compilation used different parameters.
Regarding bounding box decoding with NMS enabled:
When NMS is properly configured with bbox_decoders in your compilation settings, no additional decoding is required. The Hailo hardware performs all processing on-chip:
:white_check_mark: Bounding box coordinates are decoded from anchor/grid format
:white_check_mark: Non-maximum suppression is applied per class
:white_check_mark: Results are filtered to your specified max_proposals_per_class
:white_check_mark: Coordinates are converted to pixel units based on your image_dims configuration
Output tensor structure:
The output follows a [num_classes, attributes_per_detection, max_detections_per_class] format where each detection contains:
  • Attribute 0: x_min coordinate
  • Attribute 1: y_min coordinate
  • Attribute 2: x_max coordinate
  • Attribute 3: y_max coordinate
  • Attribute 4: confidence score
Unused detection slots will have confidence scores below your threshold or set to zero.
Hope this helps!
Hi @Ohjun_Kwon
While not a direct solution to your problem, I want to let you know about our cloud compiler. At DeGirum (a SW partner of Hailo), we developed a cloud compiler that helps users convert YOLO checkpoints to hef files: Early Access to DeGirum Cloud Compiler. You can see if the tool can help you get the compiled model you need.
