pruned YOLOv8n model on the Hailo8L
We are currently working on a project where we have deployed YOLOv8 on a Raspberry Pi. We are planning to run a pruned YOLOv8n model on the Hailo8L accelerator. Could you confirm if this is supported?
Hi @jjwon1724,
There should not be any issue using a pruned model. If you are using the model-zoo to compile your model, you might need to adjust the nodes names, but other than that you should be good.
Thank you, but it seems there was a misunderstanding. We are not looking to perform model pruning but rather to run a pruned model on a Raspberry Pi. We would like to know if there are any pruned models available or if such models are supported. Additionally, we are also looking for pruned models.
We don’t have officialy, maybe someone in the community has one,
