When the H8 M.2 module is powered, but no model is running and no interaction is happening, the module still consumes some power. Is there a way to keep the module at low power mode or sleep mode so that it won’t consume power or heat up when it not being used?
In case your host supports PCIe ASPM (Active-State power management), enabling it will decrease the H8 power consumption once the PCIe data lanes remain quiet for a long duration.
In this case, what is the typical power consumption of the M.2 ? Is it under 100 mW ?
