Hello Hailo,
I have an error when I try to parse my custom yolov7 model.
I know it exists in Hailo Zoo but I’d like to use my custom models because I plan to use other custom models not available in Hailo Zoo.
I run under Almalinux 8 (RHEL) under an Ubuntu 22 docker. I successfully installed the hailo dataflow compiler for my hailo8 card (hailo_dataflow_compiler-3.33.0-py3-none-linux_x86_64.whl) but when I try to parse, I receive this error :
root@693ec62ef232:/# hailo parser onnx /models/model_inferred.onnx
[info] Current Time: 15:23:20, 10/17/25
[info] CPU: Architecture: x86_64, Model: Intel(R) Core™ i7-10875H CPU @ 2.30GHz, Number Of Cores: 16, Utilization: 5.1%
[info] Memory: Total: 15GB, Available: 8GB
[info] System info: OS: Linux, Kernel: 4.18.0-553.77.1.el8_10.x86_64
[info] Hailo DFC Version: 3.33.0
[info] Running hailo parser onnx /models/model_inferred.onnx
[info] Translation started on ONNX model model_inferred
[info] Restored ONNX model model_inferred (completion time: 00:00:00.37)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.23)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:03.68)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 235, in translate_onnx_model
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 316, in _parse_onnx_model_to_hn
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 359, in parse_model_to_hn
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py”, line 82, in convert_model
self._create_layers()
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py”, line 39, in _create_layers
self._add_direct_layers()
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py”, line 121, in _add_direct_layers
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 434, in _layer_callback_from_vertex
self._create_ew_add_layer(vertex)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 1156, in _create_ew_add_layer
self._create_ew_layer(vertex, EWAddLayer)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 1179, in _create_ew_layer
const_layer, ew_op_input = self._create_ew_const_input_layer(vertex)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 1316, in _create_ew_const_input_layer
const_layer = ConstInputLayer.create(f"{vertex.name}_input", [const_output_shape], input_values)
UnboundLocalError: local variable ‘const_output_shape’ referenced before assignment
File “/hailo_dataflow_compiler_venv/bin/hailo”, line 8, in
sys.exit(main())
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py”, line 111, in main
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py”, line 68, in run
return self._run(argv)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py”, line 89, in _run
return args.func(args)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py”, line 212, in run
self._parse(net_name, args, tensor_shapes)
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py”, line 298, in _parse
self.runner.translate_onnx_model(
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1192, in translate_onnx_model
parser.translate_onnx_model(
File “/hailo_dataflow_compiler_venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 276, in translate_onnx_model
Following some of the directives found here Onnx to Har parsing error
I tried to remove any unknown shape using the following command, but it didn’t help. From what I could see, the models has no dynamic shape.
python -m onnxruntime.tools.symbolic_shape_infer --input /models/original_model.onnx --output /models/model_inferred.onnx --auto_merge
Am I missing something in the parsing process ?
Thank you !
