Object tracking C++
Hi everyone!
I’m looking for a Hailo-8 object tracking working example in C++.
So far, I’ve found:
Can someone put me in the right direction for implementing object tracking in C++ with Hailo?
Hi @Luiz_doleron,
We’ve taken note of your request for adding a tracker option to Hailo-Application-Code-Examples/runtime/hailo-8/cpp/object_detection at main · hailo-ai/Hailo-Application-Code-Examples · GitHub
Meantime, you can consider implementing it yourself with ByteTrack for C++
There is nice C++ implementation of BYTETrack algorithm with minimum dependencies (only Eigen3, which is header-only library): Vertical-Beach/ByteTrack-cpp: C++ implementation of ByteTrack that does not include an object detection algorithm.
It heavily resembles original Python implementation, so it will be easy to use.
