Could someone explain to me what does this mean ? It appeared during compilation step with this command
Is it bad? Is it good?
hailomz compile yolov8n --ckpt=simple.onnx --hw-arch hailo8 --calib-path train/images --classes 4--performance
with this as the .alls file
allocator_param(width_splitter_defuse=disabled)
model_optimization_flavor(optimization_level=3,compression_level=1,batch_size=32)
model_optimization_config(calibration, batch_size=32, calibset_size=2048)
quantization_param({conv*}, bias_mode=double_scale_initialization)
model_optimization_config(compression_params, auto_16bit_weights_ratio=1)
pre_quantization_optimization(zero_static_channels, policy=enabled)
model_optimization_config(checker_cfg, policy=enabled,dataset_size=2048)
post_quantization_optimization(bias_correction, policy=enabled)
post_quantization_optimization(finetune,policy=enabled, dataset_size=2048,batch_size=32,epochs=15,learning_rate=0.0001,val_images=256,val_batch_size=32,force_pruning=True)
pre_quantization_optimization(equalization, layers={conv*}, policy=enabled)
post_quantization_optimization(adaround, policy=enabled,batch_size=8,cache_compression=enabled,dataset_size=256,train_bias=False,epochs=100)
change_output_activation(gelu)
allocator_param(automatic_ddr=True, timeout=20m)
