I just wanted to reported some issues with the latest DFC (3.32) /HailoModelZoo (:
(hailo_4.22_dfc_3.32_py_3.10.6) wodzu@wodzu-Legion-Pro-7-16IRX8H:~/Development/hailo_model_zoo$ hailomz compile --hw-arch hailo8l --ckpt yolov5m_vehicles.onnx --calib-path /home/wodzu/Development/CalibFiles/ --yaml /home/wodzu/Development/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov5m_vehicles.yaml
E0000 00:00:1753722594.356106 51131 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
E0000 00:00:1753722594.358436 51131 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
[info] First time Hailo Dataflow Compiler is being used. Checking system requirements... (this might take a few seconds)
[Warning] GPU driver version should be or higher, found 535.
[Warning] CUDNN version should be 9 or higher, found 8.9.
Component Requirement Found
OS Ubuntu Ubuntu Required
Release 20.04 22.04 Required
Package python3-tk V Required
Package graphviz V Required
Package libgraphviz-dev V Required
Package python3.10-dev V Required
RAM(GB) 16 63 Required
RAM(GB) 32 63 Recommended
CPU-Arch x86_64 x86_64 Required
CPU-flag avx V Required
GPU-Driver 560 535 Recommended
CUDA 12.5 Recommended
CUDNN 9 8.9 Recommended
Var:CC unset unset Required
Var:CXX unset unset Required
Var:LD unset unset Required
Var:AS unset unset Required
Var:AR unset unset Required
Var:LN unset unset Required
Var:DUMP unset unset Required
Var:CPY unset unset Required
In file included from /home/wodzu/.pyenv/versions/3.10.6/envs/hailo_4.22_dfc_3.32_py_3.10.6/lib/python3.10/site-packages/numpy/core/include/numpy/ndarraytypes.h:1929,
from /home/wodzu/.pyenv/versions/3.10.6/envs/hailo_4.22_dfc_3.32_py_3.10.6/lib/python3.10/site-packages/numpy/core/include/numpy/ndarrayobject.h:12,
from /home/wodzu/.pyenv/versions/3.10.6/envs/hailo_4.22_dfc_3.32_py_3.10.6/lib/python3.10/site-packages/numpy/core/include/numpy/arrayobject.h:5,
from /home/wodzu/.pyxbld/temp.linux-x86_64-cpython-310/home/wodzu/Development/hailo_model_zoo/hailo_model_zoo/core/postprocessing/cython_utils/cython_nms.c:1142:
/home/wodzu/.pyenv/versions/3.10.6/envs/hailo_4.22_dfc_3.32_py_3.10.6/lib/python3.10/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:17:2: warning: #warning "Using deprecated NumPy API, disable it with " "#define NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION" [-Wcpp]
17 | #warning "Using deprecated NumPy API, disable it with " \
<Hailo Model Zoo INFO> Start run for network yolov5m_vehicles ...
[info] Translation started on ONNX model yolov5m_vehicles
[info] Restored ONNX model yolov5m_vehicles (completion time: 00:00:00.23)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.16)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:02.89)
[info] According to recommendations, retrying parsing with end node names: ['/model.24/Sigmoid', '/model.24/Sigmoid_1', '/model.24/Sigmoid_2'].
[info] Restored ONNX model yolov5m_vehicles (completion time: 00:00:00.15)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.98)
[info] NMS structure of yolov5 (or equivalent architecture) was detected.
[info] Start nodes mapped from original model: 'images': 'yolov5m_vehicles/input_layer1'.
[info] End nodes mapped from original model: '/model.24/Sigmoid', '/model.24/Sigmoid_1', '/model.24/Sigmoid_2'.
[info] Translation completed on ONNX model yolov5m_vehicles (completion time: 00:00:02.21)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.93)
[info] End nodes mapped from original model: '/model.24/Transpose', '/model.24/Transpose_1', '/model.24/Transpose_2'.
[info] Translation completed on ONNX model yolov5m_vehicles (completion time: 00:00:01.96)
[info] Appending model script commands to yolov5m_vehicles from string
[info] Saved HAR to: /home/wodzu/Development/hailo_model_zoo/yolov5m_vehicles.har
[info] Loading model script commands to yolov5m_vehicles from /home/wodzu/Development/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov5m_vehicles.alls
W0000 00:00:1753722613.251656 51131 gpu_device.cc:2344] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
W0000 00:00:1753722613.297727 51131 gpu_device.cc:2344] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
[warning] Reducing optimization level to 0 (the accuracy won't be optimized and compression won't be used) because there's less data than the recommended amount (1024), and there's no available GPU
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.55)
Calibration: 0%| | 0/64 [00:00<?, ?entries/s]/home/wodzu/.pyenv/versions/3.10.6/envs/hailo_4.22_dfc_3.32_py_3.10.6/lib/python3.10/site-packages/keras/src/layers/activations/leaky_relu.py:41: UserWarning: Argument `alpha` is deprecated. Use `negative_slope` instead.
warnings.warn(
E0000 00:00:1753722630.131184 51131 meta_optimizer.cc:966] remapper failed: INVALID_ARGUMENT: Mutation::Apply error: fanout 'yolov5m_vehicles_1/conv59_1/act_op_1/Mean' exist for missing node 'yolov5m_vehicles_1/conv59_1/bias_add_op_1/add'.
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:23<00:00, 2.73entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:24.33)
[info] Adaround skipped
Please take a look at the “Checking system requirements.” table, it is incorrectly formatted. Honestly I don’t know what is going on there.
If the dataset is larger than expected size than how increasing it might improve the results? ![]()
Regs,
Chuck
