Hi, I am using the object recognition cpp code from the “Hailo-Application-Code-Examples” repository on Raspberry Pi 5 and hailo8l. Now I noticed that the memory usage is increasing every time I run the program and this problem occurs for videos longer than 1 minute and also when reading frames from the camera. I would appreciate it if you could guide me to prevent the memory leak and fix the problem.
