Hey team,
I’m trying to setup Hailo on a docker container, for a robotics/ros2 project. My plan is to use a gst pipeline to stream the usb camera to a tcpsink, then inside the container consumer from that tcp, run inference, then pipe to another tcpsink that the host can get the output.
Host On my host machine (rpi5 running ubuntu), I have setup the hailo drivers and can see the device is registered with hailortcli fw-control identify
Docker This is my Dockerfile
`FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
— Install Python 3.11 and pip —
RUN apt-get update &&
apt-get install -y python3.11 python3.11-venv python3.11-dev python3-pip &&
ln -sf /usr/bin/python3.11 /usr/bin/python &&
ln -sf /usr/bin/python3.11 /usr/bin/python3
— Install all dependencies (build tools, gstreamer, opencv, etc) —
RUN apt-get update && apt-get install -y
sudo unzip curl wget build-essential lsb-release
python3-dev python3-setuptools python3-gi python3-gi-cairo python3-opencv python3-virtualenv
libgirepository1.0-dev python-gi-dev libcairo2-dev
libopencv-dev libzmq3-dev
libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad libgstreamer-plugins-bad1.0-dev
gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-tools gstreamer1.0-x
gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5
gstreamer1.0-pulseaudio rsync ffmpeg x11-utils vim
gcc-12 g+±12 cmake git
libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev libffi-dev
liblzma-dev libncurses5-dev libgdbm-dev tk-dev uuid-dev libnss3-dev
&& apt-get clean && rm -rf /var/lib/apt/lists/*
— Copy in setup files (models, debs, etc) —
COPY ./setup /tmp/setup
— Extract HailoRT runtime (change to _arm64.deb for ARM!) —
RUN mkdir -p /opt/hailo
— Environment for runtime —
ENV LD_LIBRARY_PATH=/opt/hailo/usr/lib
ENV PATH=$PATH:/opt/hailo/usr/bin
ENV CPLUS_INCLUDE_PATH=/opt/hailo/usr/include:/opt/hailo/usr/include/gstreamer-1.0/gst/hailo
WORKDIR /workspace
Optionally, copy in your models, .so files, test data, etc.
COPY ./models /workspace/models
COPY ./so /workspace/so
— Expose GStreamer ports —
EXPOSE 5000
EXPOSE 5001
Automate the install of some libs that need a running system to install
COPY setup/entrypoint-manual-install.sh /usr/local/bin/entrypoint.sh
RUN chmod +x /usr/local/bin/entrypoint.sh
ENTRYPOINT [“/usr/local/bin/entrypoint.sh”]
CMD [“/bin/sh”, “-c”, “bash”]`
I’m using the entrypoint as a way to install the deb once the system is up, I saw on another post that you can’t do this as part of the docker build
`#!/bin/bash
set -e
export DEBIAN_FRONTEND=noninteractive
Optional: create state dir
mkdir -p /var/lib/hailo
Check if Hailo is installed
if ! dpkg -s hailort >/dev/null 2>&1; then
apt-get update
echo “
Installing Hailo-all”
dpkg-deb -x /tmp/setup/hailort_4.20.0_arm64.deb /opt/hailo
ln -s /opt/hailo/usr/bin/hailortcli /usr/bin/hailortcli && ln -s /opt/hailo/usr/lib/libhailort.so.4.20.0 /usr/lib/libhailort.so
— Unzip and install Tappas (3.31.0) —
unzip /tmp/setup/tappas_3.31.0_linux_installer.zip -d /tmp
cd /tmp/tappas_v3.31.0
mkdir hailort
git clone GitHub - hailo-ai/hailort: An open source light-weight and high performance inference framework for Hailo devices hailort/sources
chmod +x install.sh
the help for install says to use aarch64 but it’s wrong, it’ll fail on a sub script, use arm
./install.sh --skip-hailort --target-platform arm
echo “
Hailo installation complete”
else
echo “
Hailo already installed”
fi
Clear bash command cache to ensure new tools like hailortcli are found
hash -r
Pass control to CMD
exec “$@”
I downloaded hailort_4.20.0_arm64.deb and tappas_3.31.0_linux_installer.zip from the developer area on the Hailo website.
When I check for the hailonet plugin, it’s not installed
gst-inspect-1.0 hailonet
No such element or plugin 'hailonet'
However hailooverlay and hailofilter are present. Other than the hailort deb, and tappas linux installer, what else do I need to install?
thanks
