I am attempting to run a custom model and have encountered this issue. Can anyone help me?
(venv_hailo_rpi5_examples) sdp25@raspberrypi:~/Desktop/hailo-rpi5-examples $ python basic_pipelines/pothole.py --input /home/sdp25/Downloads/raw12_4Video1.mp4 --hef /home/sdp25/Desktop/hailo-rpi5-examples/resources/potholeModel.hef --labels-json /home/sdp25/Desktop/hailo-rpi5-examples/resources/labelsPotholeModel.json
Auto-detected Hailo architecture: hailo8
filesrc location=“/home/sdp25/Downloads/raw12_4Video1.mp4” name=source ! queue name=source_queue_decode leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! decodebin name=source_decodebin ! queue name=source_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=source_videoscale n-threads=2 ! queue name=source_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 name=source_convert qos=false ! video/x-raw, pixel-aspect-ratio=1/1, format=RGB, width=1280, height=720 ! queue name=inference_wrapper_input_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailocropper name=inference_wrapper_crop so-path=/usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes/cropping_algorithms/libwhole_buffer.so function-name=create_crops use-letterbox=true resize-method=inter-area internal-offset=true hailoaggregator name=inference_wrapper_agg inference_wrapper_crop. ! queue name=inference_wrapper_bypass_q leaky=no max-size-buffers=20 max-size-bytes=0 max-size-time=0 ! inference_wrapper_agg.sink_0 inference_wrapper_crop. ! queue name=inference_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=inference_videoscale n-threads=2 qos=false ! queue name=inference_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert name=inference_videoconvert n-threads=2 ! queue name=inference_hailonet_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailonet name=inference_hailonet hef-path=/home/sdp25/Desktop/hailo-rpi5-examples/resources/potholeModel.hef batch-size=2 vdevice-group-id=1 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 force-writable=true ! queue name=inference_hailofilter_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailofilter name=inference_hailofilter so-path=/home/sdp25/Desktop/hailo-rpi5-examples/venv_hailo_rpi5_examples/lib/python3.11/site-packages/hailo_apps_infra/…/resources/libyolo_hailortpp_postprocess.so config-path=/home/sdp25/Desktop/hailo-rpi5-examples/resources/labelsPotholeModel.json function-name=filter_letterbox qos=false ! queue name=inference_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! inference_wrapper_agg.sink_1 inference_wrapper_agg. ! queue name=inference_wrapper_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailotracker name=hailo_tracker class-id=1 kalman-dist-thr=0.8 iou-thr=0.9 init-iou-thr=0.7 keep-new-frames=2 keep-tracked-frames=15 keep-lost-frames=2 keep-past-metadata=False qos=False ! queue name=hailo_tracker_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=identity_callback_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=hailo_display_overlay_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay name=hailo_display_overlay ! queue name=hailo_display_videoconvert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert name=hailo_display_videoconvert n-threads=2 qos=false ! queue name=hailo_display_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fpsdisplaysink name=hailo_display video-sink=autovideosink sync=true text-overlay=False signal-fps-measurements=true
NMS score threshold is set, but there is no NMS output in this model.
CHECK_SUCCESS failed with status=6
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.640: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.641: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.648: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.649: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.680: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.691: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.701: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.723: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.726: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.743: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.753: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.768: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.778: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.800: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.807: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.816: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.827: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.835: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.846: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:20.856: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
^CShutting down… Hit Ctrl-C again to force quit.
(Hailo Detection App:3322): GStreamer-Base-CRITICAL **: 14:02:22.975: gst_queue_array_push_tail: assertion ‘array != NULL’ failed
Exiting…
