Hi @shashi,
As you suggested, I downloaded the stdc1-sim.onnx model file from the Hailo Model Zoo and tried to compile it. However, I encountered the following error. The error message instructs me to refer to the user guide. Could you please provide guidance on this?
Thank you for your response.
(virtualenv) daeinki@linux:~/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo$ hailo optimize stdc1-sim.har --use-random-calib-set
[info] Current Time: 09:15:51, 03/05/25
[info] CPU: Architecture: x86_64, Model: 11th Gen Intel(R) Core™ i7-11700 @ 2.50GHz, Number Of Cores: 16, Utilization: 0.6%
[info] Memory: Total: 31GB, Available: 22GB
[info] System info: OS: Linux, Kernel: 5.15.0-131-generic
[info] Running hailo optimize stdc1-sim.har --use-random-calib-set
[info] Mixed Precision is done (completion time is 00:00:00.37)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [01:17<00:00, 1.22s/entries]
[info] Statistics Collector is done (completion time is 00:01:18.74)
[info] No shifts available for layer stdc1-sim/conv30/conv_op, using max shift instead. delta=0.0568
[info] No shifts available for layer stdc1-sim/conv30/conv_op, using max shift instead. delta=0.0284
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/bin/hailo”, line 8, in
sys.exit(main())
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/tools/cmd_utils/main.py”, line 111, in main
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py”, line 68, in run
return self._run(argv)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py”, line 89, in _run
return args.func(args)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/tools/optimize_cli.py”, line 120, in run
self._runner.optimize(dataset, work_dir=args.work_dir)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
return func(self, args, kwargs)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2093, in optimize
return func(self, *args, kwargs)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1935, in _optimize
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1045, in full_quantization
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1229, in _full_acceleras_run
optimization_flow.run()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
return func(self, args, *kwargs)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 326, in run
step_func()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
result = method(args, kwargs)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 124, in parent_wrapper
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 345, in step1
self.core_quantization()
result = method(args, **kwargs)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 403, in core_quantization
self._create_hw_params()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 451, in _create_hw_params
create_hw_params.run()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 50, in run
return super().run()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 150, in run
self._run_int()
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/algorithms/create_hw_params/create_hw_params.py”, line 340, in _run_int
comp_to_retry = self._create_hw_params_component(matching_component_group)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/algorithms/create_hw_params/create_hw_params.py”, line 204, in _create_hw_params_component
layer.create_hw_params(layer_clip_cfg, hw_shifts=hw_shifts)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_avgpool_v2.py”, line 301, in create_hw_params
self.avgpool_op.create_hw_params(max_final_accumulator_by_channel, hw_shifts=hw_shifts)
File “/home/daeinki/project/s5pc210/public/tizen_6.0/github/hailo/hailo_model_zoo/virtualenv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/atomic_ops/avgpool_op.py”, line 104, in create_hw_params
raise AccelerasNumerizationError(
hailo_model_optimization.acceleras.utils.acceleras_exceptions.AccelerasNumerizationError: Shift delta in stdc1-sim/avgpool3/avgpool_op is larger than 2 (2.47), cannot quantize. A possible solution is to use a pre-quantization model script command to reduce global average-pool spatial dimensions, please refer to the user guide for more info.
