Hello, I’ve read the documentation about Hailo and Raspberry Pi 5, but I didn’t understand this part. Can you help me?
I want to perform object detection with my custom-trained .hef YOLOv5 model through Visual Studio Code, rather than through the terminal. For example, I want to adjust the colors of the bounding boxes around detected objects and add text above the boxes. Also, while doing this, should I import the hailo_platform or hailo_sdk libraries on Raspberry Pi 5? If so, how should I import them and how should I code using these libraries?
So, if I’m understanding your post correctly, you want to customize, the post, post processing steps? In that case, I believe you’d have to edit the hailooverlay, hailo gstreamer element, recompile it with gcc and integrate it into your pipeline.
