i dont know what to do, just trying to install hailo-apps-infra but even to run simple code it get this
pi5@raspberrypi:~/hailo-apps-infra $ source hailo_infra_venv/bin/activate
bash: hailo_infra_venv/bin/activate: No such file or directory
pi5@raspberrypi:~/hailo-apps-infra $ source venv_hailo_apps/bin/activate
(venv_hailo_apps) pi5@raspberrypi:~/hailo-apps-infra $ pip list | grep hailo
You should see packages like hailort, hailo-tappas-core, and hailo-apps-infra.
apt list | grep hailo
This shows all installed Hailo-related system packages.
hailo-apps 25.10.0 /home/pi5/hailo-apps-infra
hailo-tappas-core-python-binding 5.1.0
hailort 4.23.0
golang-github-hailocab-go-hostpool-dev/oldstable,oldstable 0.0~git20160125.0.e80d13c-1.1 all
hailo-all/oldstable,oldstable,now 4.20.0 all [installed]
hailo-dkms/oldstable,oldstable 4.19.0-1 all
hailo-tappas-core-3.28.2/oldstable 3.28.2 arm64
hailo-tappas-core/now 5.1.0 arm64 [installed,local]
hailofw/oldstable,oldstable,now 4.20.0-1 all [installed,automatic]
hailort-pcie-driver/now 4.23.0 all [installed,local]
hailort/now 4.23.0 arm64 [installed,local]
python3-hailort/oldstable,now 4.20.0-1 arm64 [installed,automatic]
rpicam-apps-hailo-postprocess-dbgsym/oldstable 1.9.0-1~bpo12+1 arm64
rpicam-apps-hailo-postprocess/oldstable,now 1.9.0-1~bpo12+1 arm64 [installed,automatic]
(venv_hailo_apps) pi5@raspberrypi:~/hailo-apps-infra $ hailortcli fw-control identify
Identifying board
Control Protocol Version: 2
Firmware Version: 4.23.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB244601242
Part Number: HM21LB1C2LAE
(venv_hailo_apps) pi5@raspberrypi:~/hailo-apps-infra $ hailo-detect-simple
File ā€œ/home/pi5/hailo-apps-infra/venv_hailo_apps/bin/hailo-detect-simpleā€, line 3, in
from hailo_apps.hailo_app_python.apps.detection_simple.detection_simple import main
File ā€œ/home/pi5/hailo-apps-infra/hailo_apps/hailo_app_python/apps/detection_simple/detection_simple.pyā€, line 9, in
import hailo
ImportError: /lib/aarch64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.32’ not found (required by /usr/local/lib/python3.11/dist-packages/hailo.cpython-311-aarch64-linux-gnu.so)
Hey @kurniawan_anis,
The error is coming from the C++ runtime on your system:
/lib/aarch64-linux-gnu/libstdc++.so.6: version 'GLIBCXX_3.4.32' not found (required by .../hailo.cpython-311-aarch64-linux-gnu.so)
What’s happening here is that the Hailo Python extension was compiled against a newer version of libstdc++ than what’s currently on your Raspberry Pi.
The root cause: Looking at your setup, you’ve got a mixed environment that’s causing version conflicts:
  • From RPi repos: hailo-all 4.20.0, hailofw 4.20.0, python3-hailort 4.20.0-1
  • Manually installed: hailort 4.23.0, hailort-pcie-driver 4.23.0, hailo-tappas-core 5.1.0, and hailo-apps-infra 25.10.0 in your venv
You’re essentially running parts of the 4.20 stack alongside newer 4.23/5.1 components, which creates version mismatches. I’ve seen this issue pop up several times on the forum with similar symptoms.
Here’s what I’d recommend — do a clean reinstall:
dpkg -l | grep hailo
sudo apt-get remove --purge -y hailo* libhailo*
sudo apt-get autoremove --purge -y
sudo apt-get clean
sudo apt update
sudo apt full-upgrade
sudo apt install dkms
sudo apt install hailo-all
# to check if worked
hailortcli scan
Let me know how it goes!
still error
[HailoRT] [error] CHECK failed - Driver version (4.20.0) is different from library version (4.23.0)
thankyou for your answer, but unfortunately it still didnā€˜t work. but yeah fortunately after i reinstall my os, from bookworm to trixie its now work, i purge my memorycard and follow the installation form this repo, and now its work, hoping next time you guys can help me to learn more, and again thank you very much :slight_smile:
do you have some reference for me to learn how to make my hef model to be running on my own apps? i’m kinda stuck cause i didn’t find some full tutorial, sorry for this trouble, and thankyou very much
Hey @Jericho_Sanchez,
Welcome to the Hailo Community – great to have you here!
Just to double-check: do you have DKMS installed, and you’re still running into this issue? If that’s the case, could you try manually removing the driver from the kernel using the following commands?
sudo find /lib/modules -type f \( -name 'hailo*.ko' -o -name 'hailo*.ko.xz' \) -print -delete
sudo find /lib/modules -type d -name 'hailo' -print -exec rm -rf {} +
After this re run the :
sudo apt update
Hope this helps !
Great to see your interest in getting started!
You can find the documentation for the Dataflow Compiler (DFC) here:
v5.1.0 | Hailo
And the Model Zoo is available on GitHub:
GitHub - hailo-ai/hailo_model_zoo: The Hailo Model Zoo includes pre-trained models and a full building and evaluation environment
The process is pretty straightforward:
  1. Start with your ONNX or TensorFlow model.
  2. Parse the model using either the DFC or the Model Zoo.
  • If it’s not already available in the Model Zoo, we recommend using the DFC.
  1. Run the optimization step.
  2. Then proceed to the compilation step.
Hope this helps!
Hi @omria , I seem to be running into the same issue when trying to update to anything above HailoRT 4.20. I’ve ran Hailo-CLIP just fine, but trying to do anything with Hailo-Apps fails because I can’t pass the prerequisites of HailoRT 4.22.
After running the 4 commands you recommended I’m still getting told in the terminal ā€œhailo-all in already the newest version (4.20.0).ā€
My next move is a fresh OS install, but anything else I can try? I’m using Bookworm on a Raspberry Pi 5, does this only work with Trixie?
Hey @Kevin_Lim,
Yeah, the 4.23 release is only for Trixie. If you’re staying on Bookworm, you’ll need to stick with version 4.20 for now.
That said, I’d recommend making the move to 4.23 when you can - it’s going to be the last major version for Hailo8 (we’ll only be doing bug fixes going forward and adding those to the packages).
